A skeptic's view on Bohmian Mechanics
235 replies · 28K views
A. Neumaier said:
But no reference is given...
Any book or review paper on BM, or the original Bohm's two papers from 1951.
atyy said:
You are clearly not familiar with the work you cite! Ruelle's resulst are axiom A results!
He wrote several books, which you conflate. You seem to refer to his book Thermodynamic Formalism. The Mathematical Structures of Equilibrium Statistical Mechanics whereas I was referring to https://www.amazon.com/dp/9810238622/?tag=pfamazon01-20.
Demystifier said:
So, if I understood you correctly, the first spin is EPR real (because it is measured by Alice), the second spin is also EPR real (because it is measued by Bob), but both spins together are not EPR real (because nobody observed both spins). Is that what you are saying?
No. You keep conflating the broadest philosophical meaning and the EPR meaning of "real". Neither Alice's nor Bob's measures are separately EPR real as is shown by the experiments of BI violation. But if Alice or Bob make a measurement these are of course real in the sense that it is not something just in their mind, by definition of measurement in science.
Demystifier said:
This is non-realism. But I never understood why so many people think that non-determinism and non-realism is the same.
Because they are the same in the EPR definition of realism as deterministic. They are of course not the same in the philosophical definition of realism I gave that you normally use when referring to realism.
This is not a thread to discuss and correct notions of ''real'' but one on Bohmian mechanics. Please keep your remarks on topic.
I was answering a direct question by the official Bohmian around here.Either the question is on topic and then the answer is, or the question is off topic and then you should make your comment addressing the question.
RockyMarciano said:
I was answering a direct question by the official Bohmian around here. Either the question is on topic and then the answer is, or the question is off topic and then you should make your comment addressing the question.
I did it already: https://www.physicsforums.com/posts/5665529/ and posts #95-#97. But you didn't listen.
Single posts easily slide away from a topic. But a post already off-topic (and in response to one of your comments that was already off-topic) doesn't justify answering a direct question in it in the same thread. If you want to answer to something off-topic you can always open a new thread to do so, and copy the link to the originating post there.
zonde said:
Ok, then here are some of Bell's own words:
"It is important to note that to the limited degree that determinism plays a role in the EPR argument, it is not assumed but inferred. What is held sacred is the principle of “local causality” or “no action at a distance”. Of course, mere correlation between distant events does not itself imply action at a distance, but only correlation between the signals reaching the two places. These signals, in the idealized example of Bohm, must be sufficient to determine whether the particles would go up or down. For any residual undeterminism could only spoil the perfect correlation. It is remarkably difficult to get this point across, that determinism is not a presupposition of the analysis."
This is just playing semantically with the distinction between inferences and assumptions. The premise of BI that measurements in the same direction determines perfect anticorrelation measurements pressumes simultaneous existence of the spin measurement angles at certain initial time t, therefore determinism despite of how common sense this premise might appear. The fact is that this premise is implied by "no action at a distance" i.e. classical locality principle when applied to spacelike separated regions. So here the classical notion of locality based on simultaneity is used, i.e. the classical determinism with an initial state at time t=0 with a Cauchy surface of simultaneous measurements outcomes.
And please try not to use "realism" in QM context unless you mean "not solipsism" because it's very confusing what you mean with it. (is it determinism here? or causality? or particles having spin at all times?)
In the context of EPR, EPR realism is clearly well defined, so why not use it? The meaning "not solipsism" is the broadest philosophical meaning and this is indeed confusing in the quantum context of EPR.
A. Neumaier said:
In which way, then?
Classical fluid consists of many classical mutually non-entangled particles. Quantum mechanically, each of these particles can be considered to have it's own wave function, the width of which is of the order of Bohr radius. By Ehrenfest theorem, the "center" of each of these wave packets moves by classical laws. In BM, each of these wave packets is filled with a few pointlike particle (depending on the kind of atom one talks about). Within packet the Bohmian motion of the particles is highly non-classical. Nevertheless, since each particle is confined within the packet (the center of which moves classically), this non-classical motion looks pretty classical at large macroscopic distances.
RockyMarciano said:
And then in #99 you asked a question as off-topic from the OP as the ones Demystifier have been asking me.
It is my thread and my question in #99 was about an aspect of Bohmian mechanics quite related to the title. But you answered in #131 again an offtopic post by zonde to one of your off-topic posts and contribute in this way to the pollution of the thread.
I don't see how starting from your relativistic multiparticle version, this gives macroscopic continuum mechanics. Reference?
A. Neumaier said:
It is my thread
Ok, if it comes down to this I'm out.
I've just explained it in the post above, but in a sketchy way. If you don't see it I would need to write a long article with all details for you, which I don't plan to do. There is no reference because it is considered obvious, not only in the BM community, but also in the clasicallity-from-decoherence community.
Strange. In statistical mechanics, it is considered nontrivial to derive macroscopic continuum mechanics from microscopic multiparticle theory, but apparently in BM everything trivializes so that none of the difficult things must be done. It is this attitude that was criticised by Reinhard Werner in the article quoted in post #1,
Reinhard Werner said:
The Bohmian perspective seems to be the opposite. You don’t care about the hard problem, but only about that last, utterly trivial bit.
A. Neumaier said:
In statistical mechnaics, it is considered nontrivial to derive macroscopic continuum mechanics from microscopic multiparticle theory, but apparently in BM everything trivializes so that none of the difficult things must be done.
It is of course non-trivial (either with or without BM) to do it rigorously. But it is trivial if you don't insist on rigor.
Anyway, you might be interested in
https://arxiv.org/abs/quant-ph/0112005
I have noticed that many of your questions about BM totally miss the point. To exaggerate a bit, many of your questions sound to me like: OK, string theory is the theory of everything, so how string theory explains the protein folding? Reference?
BM is supposed to be a fundamental theory, but it does not mean that it can easily answer all possible macroscopic questions. See
http://robotics.cs.tamu.edu/dshell/cs689/papers/anderson72more_is_different.pdf
Therefore I ask the questions that I expect a fundamental theory to solve. I am not interested in foundations that are not even trying to address these questions. They are fake foundations, in my view.
You effectively tell me that I shouldn't be interested in Bohmian mechanics. I had noticed this myself over the course of years. But I still ask these questions so that others can see it, too.
Don't feel offended, Arnold is trying to do something never achieved before: keeping a thread about interpretations of QM as much as possible on-topic and philosophy-free. Almost succeeding.
I am not sure whether you are really interested in BM (or only interested in disproving* BM), but if you are, it seems to me that you are interested for wrong reasons. From a Bohmian point of view, standard QM is an effective theory emerging from more fundamental BM. For many high-level questions it is much more appropriate to use effective theory instead of fundamental theory. Different physical questions need different effective theories. See the paper "More is different" by Anderson I linked above. So yes, in a way I am telling you that you shouldn't be interested in Bohmian mechanics, just as I would tell you that you shouldn't be interested in quantum electrodynamics if you asked me about radiation from antenna (for which classical electrodynamics is a much better tool).
(*I have never seen that you said anything positive about BM. In all these years you either criticize it, or ask questions which sound like "Ha, I bet you can't answer this one!".)
I am highly interested in good and strong foundations of quantum mechanics. As part of my efforts there I look at what each interpretations contributes to the understanding of the questions that I find good foundations should settle. In particular, I ask questions, give answers, and criticize in this spirit.
This is because I share the sentiment of Reinhard Werner expressed in the quotes in post #1 that, unfortunately, there is very little positive to say about BM. Querying for possible positive things that I might have overlooked only confirms that. These queries are dismissed with comments such as
DrChinese said:
I don't think so. On the other hand, demystifier is on record saying "... it cannot be said that there exists a well-defined relativistic QM." There's always an out! :biggrin:
But now
http://xxx.lanl.gov/pdf/quant-ph/0609163v2
Demystifier said:
It is a statistical effect. See e.g.
https://arxiv.org/abs/1205.1992
he thinks there is one. Though it is a nonstandard one that does not make the same predictions as QED. That's why I had asked
A. Neumaier said:
When viewed in the large ##N## limit, does your many-particle relativistic quantum mechanics reproduce macroscopic continuum mechanics? Or is it just a proposal studied for its own sake?
Because this is the least test a theory different from QED must pass to be taken seriously. Unfortunately, the answer I got was only
Demystifier said:
There is no reference because it is considered obvious, not only in the BM community, but also in the classicality-from-decoherence community.
although the question is about the relativistic multiparticle theory itself and not the Bohmianization of it. Bohmian mechanics may be confident that they predict the same relativistic results as the theory that they Bohmianize, but if the latter makes wrong predictions then the Bohmian version makes the same wrong predictions.
Thus it is important to have clarified the status of the unbohmianized version. And in contrast to what demystifier claims, the classicality-from-decoherence community has never studies this relativistic quantum theory. Not because they consider it obvious (where is the reference that justifies this claim?) but because they consider it an exotic proposal.
If so, why are you still so much interested in it? Why do you waste your time? Why don't you just ignore it?
I often criticize Copenhagen, MWI, or minimal ensemble, but I would never do that if I didn't also see many positive things about those. On the other hand, I spend no time to criticize thermal interpretation.
I had answered this already:
Here is another objection that I realized in the last thread, which unfortunately got hijacked and locked.
Apparently, Bohmian mechanics needs to model the complete system, including the apparatus and the environment, in order to (perhaps) agree with the QM predictions. In response to a question by @stevendaryl, Demystifier replied:
Demystifier said:
When the measurement setup is changed, then it is ##P(\lambda)## that gets modified.
I agree that this must happen in BM, but it seems to me that this makes BM superdeterministic. In a deterministic theory, the assumption ##P(\lambda,\vec a,\vec b) = P(\lambda)## is usually taken to model the free choice of the experimenters. If BM can only reproduce QM by taking the measurement process into account, it appears to deny this free choice.
I'm glad that you asked it. Indeed, there is no free choice in BM because it is a fully deterministic theory. However, it is not superdeterministic theory. In a superdeterministic theory the initial conditions are fine tuned in order to simulate a law which does not really exist as a law. (For instance, 't Hooft studies superdeterministic local hidden variables for QM, where the appearance of non-locality is simulated by fine tuned initial conditions for local hidden variables.) There is no such fine tuning of initial conditions in BM. Similar to classical mechanics, BM is fully deterministic but not superdeterministic.
