A speck of dust that carries charge in a electric field?
The discussion centers on the behavior of a speck of dust with a mass of 1 x 10-18 kg and a charge equal to one electron's charge (approximately -1.6 x 10-19 C) in a uniform electric field of strength 100 N/C and a gravitational field of 9.8 N/kg. Participants confirm that the speck can be treated as a point charge, which possesses its own radial electric field. The charge is negative, and the question regarding the "sign of the charge on the surface" refers to labeling the particle as negative, while the Earth's surface nearby will have an induced charge due to the speck.
  • Understanding of point charges in electrostatics
  • Familiarity with electric fields and their properties
  • Basic knowledge of gravitational fields
  • Concept of induced charge in electrostatics
  • Study the principles of electric fields and point charges in detail
  • Learn about the concept of induced charge and its implications in electrostatics
  • Explore the relationship between electric fields and gravitational fields
  • Review the mathematical representation of electric field lines and their significance
Students studying physics, particularly those focusing on electrostatics and electric fields, as well as educators seeking to clarify complex concepts in homework assignments.
Tangeton
A speck of dust has a mass of 1 x 10-18 kg and carries a charge equal to that of one electron. Near to the Earth's surface it experiences a uniform downward electric field od strength 100NC-1 and a uniform gravitational field of strength 9.8Nkg-1.
Draw a diagram which shows the electric field pattern and the sign of the charge on the surface.
I find my college's homeworks very confusing in wording and just generally to understand. I can do more stuff with exam Q's most of the time, but these homework bring me out of the safe zone because I can never actually understand what they are trying to say.
First of all, It says the speck of dust itself has a charge, does that mean that I can treat it as a point charge?
Secondly, if it's equal to one electron's charge, does it automatically make the charge negative? The homework sheet says "Electronic Charge = 1.6 x10-19", while the formula booklet says there is a minus before all that so I don't know whether it is a positive charge or a negative charged dust speck.
Thirdly, if it is a point charge, does it mean that it will have its own radial field that, depending on whether it is positive or negative, goes outwards or towards the charge? And that there is going to be a background electric field that is going downwards from most positive to least positive at the same time?
Fourthly, what does it mean by ''the sign of the charge on the surface''? Does it mean that I label the particle negative or positively?
Since this forum requires an attempt at answer:
That depends on what you want to calculate. For the sketch, it should not matter (a sphere is easier to draw clearly).
Probably, as an electron has a negative charge.
It will have its own electric field, independent of the size of the speck of dust. You probably don't need this field.
Probably, but I don't see the point in this part of the homework question.
You should show the E field pointing from the Earth to the speck (quiz: why not from the speck to the earth?). The surface they refer to must be the earth, since it's obvious what the charge on the speck is. The Earth's surface in the immediate vicinity of the speck will have charge induced due to the presence of the speck.
The wording on this problem does indeed leave much to be desired.
Ah, good idea.
I doubt that's relevant, considering the tiny charge of the speck.
Yes, the wording of the problem is problematic.
But, it's a tiny problem! The flux lines have to end somewhere, and that somewhere is the earth.
  • · Replies 16 ·
