Abstract Algebra First Isomorphsm Theorem
6 replies · 3K views · last reply
CurtBuck
Use the First Isomorphism Theorem to show that Q[x]/(x^3-3) is isomorphic to {a+b*sqrt(3)}
First Isomorphism Theorem:
If f: G-> H is a homomorphism then G/ker(f) is isomorphic to im(f)
I understand that I need to show that Q[x] is homomorphic to {a+b*sqrt(3)} with a kernel of x^3-3. I am really struggling in finding that homomorphism. I see the connection between sqrt(3) and x^3-3, e.g. sqrt(3) is a root of x^3-3, but I don't understand how this helps.
It is clear that you should choose f(q)=q, for every [tex]q\in \mathbb{Q}[/tex]. So you only need to know what f(x) is. What you certainly want is [tex]f(x^3-3)=0[/tex]. Using that f should be a homomorphism yields that [tex]f(x)^3-3=0[/tex]. So what should be f(x)?
First, I apologize, I meant to right that the polynomial being modded out of Q[x] is x^2 - 3, not x^3 - 3.
So that being said, I understand that f(x)^2 - 3 = 0 implies that f(x) = sqrt(3).
But then how would one generalize this?
Well, f(q)=q for [tex]q\in \mathbb{Q}[/tex] and [tex]f(x)=\sqrt{3}[/tex].
So [tex]f(a+bx)=a+b\sqrt{3}[/tex] and [tex]f(a+bx+cx^2)=a+b\sqrt{3}+c\sqrt{3}^2=a+3c+b\sqrt{3}[/tex]. Now try to generalize what I'm doing here...
I understand what you're doing there.
Two more things:
How do I prove that this a homomorphism?
Also, wouldn't 0 also be in the kernel? Is this allowed for the First Isomorphism Theorem?
Hmm, showing that this is a homomorphism is indeed not so easy.
First take a general polymial and calculate
[tex]f\left(\sum_{k=0}^n{a_kx^k}\right)[/tex]
This will help you. Then with this information, you only need to calculate
[tex]f\left(\sum_{k=0}^n{a_kx^k}+\sum_{k=0}^n{b_kx^k}\right)[/tex]
and
[tex]f\left(\sum_{k=0}^n{a_kx^k}\sum_{k=0}^n{b_kx^k}\right)[/tex].
As for the other question. Of course 0 is going to be in our kernel, and this is not a problem. The first isomorphism theorem requires us that the kernel equals [tex](x^2-3)[/tex], that is: the ideal generated by [tex]x^2-3[/tex]. And 0 is in this ideal...
To show that "evaluation at [tex]\sqrt{3}[/tex]" is a homomorphism, it's actually a little easier to prove a general theorem that "evaluation maps are homomorphisms":
If [tex]A \subset B[/tex] are rings and [tex]\xi \in B[/tex], then the "evaluation at [tex]\xi[/tex]" map [tex]\mathrm{ev}_\xi: A[X] \to B[/tex] given by extending the inclusion map [tex]A \hookrightarrow B[/tex] by sending [tex]X \mapsto \xi[/tex] is a homomorphism.
(You can generalize this a little further by letting [tex]A[/tex] be embedded in [tex]B[/tex] via a homomorphism [tex]\varphi: A \to B[/tex] rather than directly a subring of [tex]B[/tex]; then the evaluation map extends [tex]\varphi[/tex] by sending [tex]X \mapsto \xi[/tex], rather than extending the inclusion map.)
