Abstract Algebra Proof question
The discussion revolves around proving that the greatest common divisor (gcd) of two integers \( a \) and \( b \), expressed in terms of their prime factorization, is given by \( (a,b) = p_{1}^{n_{1}}p_{2}^{n_{2}}...p_{k}^{n_{k}} \) where \( n_{i} = \min(r_{i}, s_{i}) \). Participants clarify that each \( n_{i} \) represents the minimum power of the prime \( p_{i} \) in the factorizations of \( a \) and \( b \). An example using \( a = 2^2 \times 3 \) and \( b = 2 \times 3^4 \) illustrates the concept, confirming that \( (a,b) = 2^1 \times 3^1 = 6 \).
  • Understanding of prime factorization
  • Familiarity with the concept of greatest common divisor (gcd)
  • Basic knowledge of the minimum function in mathematics
  • Experience with rigorous proof techniques in abstract algebra
  • Study the properties of gcd and lcm (least common multiple) in number theory
  • Explore Euclid's algorithm for computing the gcd
  • Learn about the Fundamental Theorem of Arithmetic and its implications
  • Investigate the role of prime factorization in algebraic structures
Students of abstract algebra, mathematicians interested in number theory, and anyone seeking to deepen their understanding of gcd and prime factorization concepts.
Gamble93
Let a=p_{1}^{r_{1}}p_{2}^{r_{2}}...p_{k}^{r_{k}}, b=p_{1}^{s_{1}}p_{2}^{s_{2}}...p_{k}^{s_{k}} where p_{1},p_{2},...,p_{k} are distinct positive primes and each r_{i},s_{i} ≥ 0 Prove that (a,b)=p_{1}^{n_{1}}p_{2}^{n_{2}}...p_{k}^{n_{k}} \mbox{ where for each } i \mbox{, } n_{i}=\mbox{minimum of } r_{i},s_{i}.
This is a question from a homework assignment from a first course in abstract algebra. The class has only been going for a few weeks. We've covered the long division algorithm for integers, the fundamental theorem of algebra, Euclid's algorithm and a few other menial theorems.
I've tried letting c=p_{1}^{h_{1}}p_{2}^{h_{2}}...p_{k}^{h_{k}}, h_{i}≥<br /> 0 be a divisor of a and b and then I just get lost. I'm not used to rigorous proof at all and this course has been a struggle for me while I get acquainted with the many styles of proof. Any sort of help or even guidance in the right direction would be much appreciated.
I take it (a,b) = gcd(a,b)? I'm not sure if it is just a difference in notation or not, but I think your prime factor representations should be infinite, without a index k where it stops. It's a product of all primes to different powers greater than or equal to 0, and there are an infinite amount of them (many of them will have a power of 0). For a proof like this, you have two things to show: the first is that your candidate for the gcd(a,b) divides both a and b. Here our candidate is the right side of the (a,b)= (p_1)^{n_1}(p_2)^{n_2}... equation. Each n_i is min{r_i,s_i}, so we can divide both a and b with our candidate, since for each prime p_i, the corresponding prime in a and b will either be canceled out or have a power of max{r_i,s_i}-min{r_i,s_i}. With this in mind you can formally show that your candidate divides both a and b. After this, you need to show that it is in fact the largest number that divides both a and b. A good start is to assume there is a larger one and show it is impossible.
I'm having trouble understanding this statement. Can someone provide an example?
The gcd of (a,b) = p_1^{\min\{r_1,s_1\}}\cdots p_n^{\min\{r_n,s_n\}}
You take the minimum of the powers from a and b.
Suppose a = 2^2\times 3 and b = 2\times 3^4
(a,b) = 2\times 3
a has a 2 with power 2 and b with power 1. I took the min. I do this for all primes.
Sure: we can write 108 as 108=(2^2)(3^3)(5^0)(7^0)... and 405 as 405=(2^0)(3^4)(5^1)(7^0)(11^0)... . Using our formula for (108,405)=(2^min{2,0})(3^min{3,4})(5^min{0,1})(7^min{0,0})(11^min{0,0})... we see that
(108,405)=(2^0)(3^3)(5^0)(7^0)(11^0)... = 9. This divides both:
108/9 = (2^2)(3^(3-2))(5^0)(7^0)...=(2^(max{2,0}-min{2,0}))(3^(max{3,4}-min{3,4}))(5^(max{0,0}-min{0,0}))...
if a prime does not occur in the prime factorization of an integer, it can be safely ommitted (the only 0 powers we need are the primes that occur in the factorization of one of a or b, but not both). no one I've ever come across factors 7 as:
20305071110130...
Definitely Deveno, but it's good to understand that it is an infinite product, otherwise you lose the uniqueness of each factorization.
