Why does the IEEE recommend using ac and dc instead of AC and DC?
  • Thread starter Thread starter thegreenlaser
    Ac Dc
The IEEE recommends using "ac" and "dc" instead of "AC" and "DC" to reflect their evolution from acronyms to common nouns. This recommendation is outlined in the IEEE's document on unit symbols and abbreviations. While many professionals continue to use the capitalized forms, the IEEE's stance aims to standardize terminology in technical writing. The discussion reveals confusion among users regarding the rationale behind this preference, especially since it deviates from conventional capitalization practices for acronyms.
  • Understanding of electrical engineering terminology, specifically alternating current (AC) and direct current (DC).
  • Familiarity with IEEE standards and guidelines for technical writing.
  • Knowledge of unit symbols and their proper usage in engineering contexts.
  • Awareness of the evolution of language in technical fields, particularly regarding acronyms.
  • Research IEEE standards on unit symbols and abbreviations for electrical engineering.
  • Explore the historical context of acronyms transitioning to common nouns in technical language.
  • Investigate the usage of "var" for reactive power and its implications in engineering documentation.
  • Examine best practices for technical writing in engineering to enhance clarity and adherence to standards.
Electrical engineers, technical writers, and professionals involved in standards compliance will benefit from this discussion, particularly those focused on accurate terminology in technical documentation.
thegreenlaser
I was a little surprised to find out that the IEEE recommends using "ac" and "dc" for alternating/direct current rather than "AC" and "DC." (Google "Recommended Unit Symbols, SI Prefixes, and Abbreviations - IEEE")
Apparently non-capitalized is the "correct" way but I've mostly seen them capitalized. Capitalized seems to make more sense since they're acronyms... Does anyone know why they're not supposed to be capitalized?
Also, my main question: are "ac" and "dc" really preferred in cases where I can choose either way? (I'm not submitting to IEEE) From my experience, most people seem to use the upper-case acronyms, and I suspect most people will be thrown off by the lower-case acronyms even if they're technically correct.
I agree w/ you that lower case will likely be off-putting to most people. Even laymen are used to seeing those terms and seeing them capitalized. I can't imagine why the IEEE would even SUGGEST using lower case, much less actually recommend it.
I usually capitalize them when using them alone, to make them more obvious visually. When appending them to modify a quantity, I usually use lower case, like with Vdc, Vac, Vrms. Of course, I don't set the standards... :smile:
I agree w/ that but as attachments (subsidiarly elements) in a term, that's a different story than when they are stand-alone.
There's a sort of convention that ac stuff is designated with lower case, dc stuff with upper case, like: 208v 3-phase power; 12V car battery. I don't think it's exactly cast in concrete or anything. And the IEEE can recommend anything they want, it doesn't necessarily mean everyone will abide by it.
I've seen that convention used for variables, (e.g. i(t) and v(t) for time-varying current and voltage versus I and V for constant current and voltage) but I've never seen it used for units...
I know I'm not bound by IEEE recommendations, but I'm confused as to why they would so specifically go against the obvious choice (capitalization) if there's no good reason for it. Even their document says that "ac" and "dc" are an exception compared to other acronyms, but they don't explain why. If there is indeed a good reason then I'd probably prefer to follow the convention, but I can't seem to find what that reason is.
Also, I noticed that they recommend "var" for reactive power rather than "VAR" or "VAr," which seems inconsistent with using "VA" for real power... Again, I'm just confused why they go against what seems like the obvious choice to me.
I think the idea is that AC and DC are becoming more like nouns rather than an acronym. It's probably like using laser instead of LASER. LASER actually stands for "light amplification by stimulated emission of radiation".
It still doesn't make sense to use "ac" because I would read that as something like "ack" every time I saw it. I couldn't even pronounce "dc" but my Polish friends probably could. Maybe there are Slavic language speaking people taking over the IEEE? I'm kidding of course.
A bit of googling seems to confirm what you're saying; however, I agree that it still doesn't make much sense. I would think the fact that we say "ay see" rather than "ack" would solidify ac as an acronym rather than a word.
  • · Replies 25 ·
  • · Replies 78 ·
17K
12K
  • · Replies 21 ·
13K
