Still confused.Let me ask you some more.
1)I read that if we have in a circuit both DC and AC voltage sources,then we analyze them separately.For DC analysis i open all the capacitors.For AC analysis
i substitute all DC voltage sources with AC grounds and i substitute the capacitors(coupling-bypass capacitors) with short circuits.So there are capacitors i cannot substitute with short circuits right?
2)If i do what i told earlier then in DC analysis(opening the capacitor) i get that VR=Vout=10V.
If i do in AC analysis what i said then i have the AC source connected across with both the resistance and the diode(resistance and diode in parallel).Now the current will
<<prefer>>(for the reasons you well explained) to pass through the diode.So current through resistance almost zero.So ac voltage through resistance almost zero?
And basically because the diode is ideal,the AC source cannot have any impact on R(=Vout) the way i see it.But earlier we reached to the point that it has the same behavior with the AC source,so it does have an impact on Vout.So we reach to the point that in this case i cannot substitute it with a short circuit?
3)If in a circuit there is absolutely no reference to steady states,switches(open-closed) etc can i substitute them with either short or open circuits(depends on source)?Because it is a little confusing.In first and second order circuit analysis,it is very different.We don't just open the capacitor,we find relations.But in other books,without any reference to even tell us that it was in steady state,it just opens the capacitors and move on with the calculations.I am not sure if made myself clear...
rude man said:
C charges to a voltage of the peak voltage on its left side minus the 10V battery voltage on its right side on the 1st ac cycle.. Is there a subsequent significant discharge path anywhere? Remember the statement that the RC time constant is much larger than the time of 1 cycle of the ac source.
Hint: you showed a diagram with R missing. You didn't give the right reason, but that move is good. Why?.
Because it cannot discharge once charged?
rude man said:
So what is that capacitor voltage after the 1st cycle?
You said that it charges to a voltage of the peak voltage on the left minus the 10 battery voltage,so i assume it starts from -10,rises up to +10 and stays there.
But i have a question
4)How can it reach the peak,if the difference between time constant and period is that big.I mean it needs 4-5 time constants to get fully charged,but during just one time constant the AC source would probably have done many cycles.How does it allow the capacitor to reach the peak?
