Control AC Fan Motor with DAQ: AC Voltage Driver?
  • Thread starter Thread starter adrianstraka
    Ac Voltage
The discussion centers on controlling an AC fan motor using a Data Acquisition (DAQ) system to vary the amplitude of a 110V AC sine signal. Users suggest utilizing a variac, specifically a Staco Variable Transformer, for effective speed control. Additionally, a triac regulator is proposed as a viable alternative for applications that do not demand high power. These methods provide practical solutions for managing fan motor speed through voltage modulation.
  • Understanding of AC voltage drivers
  • Familiarity with Data Acquisition (DAQ) systems
  • Knowledge of variable transformers, specifically Staco Variable Transformers
  • Basic principles of triac regulators
  • Research the operation and application of Staco Variable Transformers
  • Learn about triac regulators and their use in AC motor control
  • Explore the configuration and programming of Data Acquisition (DAQ) systems for signal modulation
  • Investigate safety protocols for working with high voltage AC systems
Electrical engineers, control system developers, and anyone involved in AC motor speed regulation will benefit from this discussion.
adrianstraka
AC voltage driver??
Do AC voltage drivers exist?
I want to develop a control system using a DAQ to vary the amplitude of a 110V AC sine signal being fed into a 110V AC fan motor, in order to control its speed. Does anyone have any suggestions
The method I was going in is to complicated, it involves generating a variable +/- 10v sine signal from the DAQ feeding it into a power amplifier and then feeding the amplified voltage to the motor.
I appreciate all help and suggestions.
Thanks
With the currents you need to run a fan, I would suggest using a http://www.variac.com/staco_Variable_Transformer_Map.htm" .
Welcome to PF.
A triac regulator might work too if you don't require much power.
Most likely this can only be answered by an "old timer". I am making measurements on an uA709 op amp (metal can). I would like to calculate the frequency rolloff curves (I can measure them). I assume the compensation is via the miller effect. To do the calculations I would need to know the gain of the transistors and the effective resistance seen at the compensation terminals, not including the values I put there. Anyone know those values?
  • · Replies 47 ·
  • · Replies 68 ·
16K
