Acceleration due to air resistance?
The discussion centers on calculating the acceleration of a projectile due to air resistance, specifically for a long-range projectile intended to travel up to 2 miles. The user employed the drag force equation from a Physics Forums thread, using parameters such as drag coefficient (Cd = 0.295), air density (rho = 1.22752 kg/m³), cross-sectional area (A = π * 2² m²), and velocity (v = 240 m/s). The calculated acceleration of approximately -5698 m/s² was deemed incorrect, prompting inquiries about incorporating gravitational acceleration and air resistance for more accurate velocity estimations. The complexity of the problem is highlighted, particularly the variability of Cd with velocity and the implications of a low ballistic coefficient.
  • Understanding of drag force equations in physics
  • Familiarity with projectile motion principles
  • Knowledge of fluid dynamics, particularly drag coefficient (Cd)
  • Basic calculus for solving differential equations
  • Research the effects of varying drag coefficients on projectile motion
  • Learn about the ballistic coefficient and its impact on flight stability
  • Explore numerical methods for solving differential equations in projectile motion
  • Study the integration of gravitational forces in projectile trajectory calculations
Physics students, aerospace engineers, and hobbyists interested in projectile dynamics and air resistance calculations.
evilmigit14
a friend of mine asked if i could help him work out some equations for a (fairly) long range projectile, to go no farther than 2 miles or so. i have everything reasonably worked out except for acceleration due to air resistance. I'm using the equation from https://www.physicsforums.com/showthread.php?t=9066" thread to calculade Fd, and Cd=.295, rho=1.22752kg/m^3, A=pi.2^2m^2, v=240m/s, firing an object with a mass of .23kg. (Cd and rho both came from the Nasa website) I did the calculations and got an estimated acceleration of about (-)5698 m/s^2, which obviously cannot be right.
I was also wondering if there is any way to get a more accurate velocity by factoring in acceleration of gravity and air resistance. I'd assume it'll take some nasty algebra/calculus, but i can't figure it out on my own.
any help is greatly appreciated.
Area = 4pi square meters and a mass of only 0.23 kg? That sounds pretty much like a 2 meter diameter balloon to me.
If you tried moving something as big and light as that at 240 m/s (mach 0.7), the deceleration would indeed be large.
I think the area is 0.04pi m^2. Still very large. A projectile with a 20 cm diameter with a mass of only 0.23 kg can´t fly at 240 m/s.
Its not a wieldy problem, first Cd is not a constant at all but varies with velocity in a complex fashion, making this impossible to find an exact closed form solution. However, you could approximate a soln using a fixed Cd and initial V that's only subject to drag and gravity. But check the diameter, this is as pointed out much too low a ballistic coefficient to go anywhere due to whiffle ball effect.
  • · Replies 39 ·
  • · Replies 24 ·
