Acceleration due to gravity, and the force of landing on the ground
Impact force calculations depend on the stopping distance or time, which are not easily defined in real-life scenarios. When a person falls from a height, the force upon impact can be derived from their velocity at impact, but assumptions about constant force can lead to inaccuracies. Using energy principles, the kinetic energy of the fall can be equated to the work done by the stopping force over a distance. In cases where a trampoline or cushion is involved, the calculations become more complex due to variable forces during deceleration. Overall, understanding the nuances of impact force requires a comprehensive model of the landing surface and the stopping process, which is often not addressed in basic physics problems.
SignSeeker7
I'm quite confused about impact force and weight, as well as momentum. Assuming someone were to fall from a 5-story building, about 20 m, how would you calculate the force upon impact? I know it involves momentum, but I can't quite grasp it.
Also, if someone fell from the building, but instead of landing on the concrete below, they instead landed on a trampoline or blanket suspended above the ground, something that would slow them down without being lethal, how would you show that? Would it involve the same equation?
EDIT: I'm ignoring air resistance as well. In case that changes things.
The reason you are confused about the "force of landing" is that this is not a well-defined concept without more information being given. You know the force of gravity, and the acceleration it produces (that's just g, a constant), so it's easy to get the velocity upon impact. But how do you convert that into a force? You need to know either the distance over which the falling person is stopped, or the time to stop them. Either of those will let you calculate the force, but even then you have to assume the force is constant, which is not a very good assumption at all. So anything you do is going to be pretty rough. However, if you do have a constant force of impact, and you know the distance over which it applies (so a harder surface would compress a smaller distance, for example), then you just say the force times the distance equals the kinetic energy of the falling person, and you do it all with energy. If you instead know the time it takes the person to stop, you would do it with momentum-- the force times the time must equal the momentum that the falling person acquired while falling.
But what I really want to stress is that you wouldn't know these things in any real application-- you would need a much more complete model of the response of the ground or trampoline or whatever. Then you would need to do a careful calculation of the stopping process, that was much more difficult than the simple calculation of the falling process. So that's why you really don't encounter the "force of impact" very often in basic physics problems.
So would it be bad to assume that the person would stop instantaneously? I would think that would be incredibly difficult to happen in real life.
Yes, instantaneous stopping would require an infinite force. The fact is, we usually choose not to care what the force of stopping is, instead we focus on what is much easier to know-- the energy released when the person is stopped, and the momentum required to stop them. Going deeper into the stopping process is an issue for paratroopers and basketball sneaker designers!
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
