Acceleration of a block on a massive pulley
The problem involves a block of mass 0.7 kg hanging from a string around a hollow hoop with a mass of 1.3 kg and a radius of 0.4 m. The block descends due to gravity, and the goal is to find its acceleration. The equation used for acceleration, a = -g(m1-m2)/(m1+m2+0.5mp), is incorrect for this scenario since it assumes a solid pulley with two hanging masses. Instead, the hollow nature of the pulley must be considered in the calculations. The correct approach will yield the accurate magnitude of acceleration for the block.
EchoTheCat
A block of mass MB = 0.7 kg hangs from a string wrapped around a hoop that can rotate around its center. The hoop has a mass of MH = 1.3 kg and a radius of R = 0.4 m. The block descends under the influence of gravity. What is the magnitude of the acceleration of the mass in m/s2?
a = -g(m1-m2)/(m1+m2+.5mp)
where, m1 and m1 = masses of the blocks and mp = mass of the pulley
a = -9.8*(0.7)/(.7+.5*1.3) = -5.081 m/s/s
The equation you quote appears to assume a pulley which is a solid disk or cylinder with two masses hanging, one from either side. That's not the problem at hand. This pulley is hollow. There is a mass hanging from only one side.
