Acceleration of falling object on impact
The discussion revolves around determining the height from which an object must be dropped to achieve an impact acceleration of 1000g's upon hitting the ground. Participants explore various equations and concepts related to free fall, impact velocity, and deceleration, while considering the complexities involved in accurately estimating the necessary parameters.
  • Experimental/applied
  • One participant expresses confusion about the necessary height to achieve 1000g's of impact, noting the equations for free-fall and impact velocity but questioning their applicability.
  • Another participant clarifies that the instantaneous acceleration at impact cannot be simply derived from the velocity at that moment without knowing the duration of the impact.
  • Some participants discuss the conservation of energy, indicating that mass cancels out in the equations used to calculate height based on potential and kinetic energy.
  • One participant suggests estimating the stopping time to refine height calculations, proposing a specific duration of 0.01 seconds for the impact.
  • Another participant introduces the concept of deceleration based on the height fallen and the stopping distance, providing an example to illustrate the relationship.
  • Concerns are raised about the difficulty of determining the stopping distance ("x") and the variability of this parameter based on different conditions.
  • Several participants emphasize the complexity of the problem, noting that many variables affect the outcome, including the properties of both the object and the ground.
  • One participant suggests that practical experimentation may be necessary to obtain accurate results, including measuring the impact and resulting damage.
  • A later reply questions whether the original question posed was well-defined, suggesting a need for clarification on the actual goals of the inquiry.
Participants generally agree on the complexity of the problem and the need for careful consideration of various factors, but there is no consensus on a definitive method or solution to determine the required height for achieving 1000g's of impact.
Participants highlight limitations in the assumptions made, particularly regarding the duration of impact and the variability of the stopping distance, which complicate the calculations and estimations involved.
sunny0302
I have been out of school for a few years so my physics is rusty. I need help figuring something out for my job. I need to know how high I must drop an object so that it hits the ground with an impact of 1000g's. The object is a cylindar and weighs 2lbs.
I have been confusing myself. I know that the object will fall with 1g acceleration. I think need an equation that allows me to find the instantaneous acceleration at the moment of impact. I think I can assume an infinitely hard ground for now. I have found that instantaneous acceleration is delta v/delta t where t->0.
If a=9806 m/s^2 then as t-->0, the velocity would be 9806 m/s?
So then I think I need to use another equation to back out the height
I found this equation for free-fall with no air resistance but I'm not sure it helps.
y(t)=-1/2*g*t^2 + v_o*t + y_o
I found this equation for impact vel just before impact = sqrt(2*g*h). But if I set it equal to 9806 I get h=4,903,000 meters...that seems very high.
I am also worried when the equations don't take mass into account.
Another option I thought of:
F=ma
F=(.907 kg*9806m/s^2)
F=8894N
And then I would need some sort of equation that let's me back height out of Newtons.
Can anyone help me? I'm going in circles.
No. For any velocity, if the object comes to rest in a time t->0, the acceleration of the object tends to infinity!
[tex]<a> = \frac{\Delta v}{\Delta t} = \frac{v}{\Delta t}[/tex]
So, unless you can estimate the duration of impact, it is difficult to find out the velocity required to produce that acceleration. It is very likely that the velocity required is much less than 9806m/s, since the object is likely to stop in much less than a second.
This equation comes from conservation of energy.
[tex]\Delta Potential Energy = \Delta Kinetic Energy[/tex] (magnitude-wise)
The mass actually cancels out, so no worries there.
[tex]m g h = \frac{1}{2} m v^{2}[/tex]
[tex]v = \sqrt{2gh}[/tex]​
Ok, so if I assume it stops in .01 s, the velocity changes to 98.06s.
The using the second equation I would get h=490.3 meters.
Is there any good way/equation to estimate how long it would take to stop so I can get a better height estimate?
If an object falls from a height h, and stops in a distance x, the deceleraton a is gh/x meters per second2. If h is 10 meters, and x = 1 cm, then a = 1000 g's.
Bob S
Bob S
Well, that seems simple enough. Thanks!
It seems simple, but figuring out the "x" isn't. That x is NOT something you can just approximate off the top of your head, either. You must do some research to figure this out. Also, keep in mind that the "x" will change as the drop height changes.
Anyway, if you're just going to approximate x, you might as well skip all the math and physics and this entire thread, and simply guess the height. It saves a lot of trouble and calculation, and the end result is pretty much the same...
Assuming I know the weight, cross-sectional area and material of the object, are there any equations that can help me figure x out? Are there standard "give" estimated values for the ground. For instance, 40N of force makes the ground give .1 cm?
calculating the length/duration of the deceleration zone is tricky, it would be much easier to measure it if you have access to accelerometers, otherwise you have to think about orientation of the object under impact, the stiffness and geometry of the object, dynamics of crumple zone etc etc…. it could get pretty complex pretty quick
Yeah, exactly. It could, and should get VERY complex VERY quickly. There's so many variables to consider, the properties of the ground, the object, etc. I think it's something that can only be approximated sufficiently with experiment. And, actually, that doesn't seem very difficult. Just take the cylinder and drop it, and measure how big of a dent it made.
Depending on the variables though, it might make no dent at all. In which case you should look at better equipment...accelerometer, high speed camera, whatever else there might be. Hell, you could probably even figure out how to use an egg to help you get the results.
Ultimately the sophistication of the measuring equipment comes down to how much your job really cares about getting accurate results. If they say that they want you to figure it out only using google and your imagination, tell them to be prepared for an error factor of a few hundred percent at best, imo.
As seen in the previous responses, this is a very complicated question. Which to me, implies that the wrong question may have been asked. You might want to discuss this with whoever posed the question, and find out from them what it really is they want to do. In other words, I doubt that what they really want to do is "hit the ground with an impact of 1000g's" since that is a pretty poorly defined request.
Thanks so much for your input. There is another way to test the shock. There is a machine but it costs $ so I think they wanted to see if they could just drop it and get about the same results. It looks like, unless they are willing to drop it many times from different heights and then measure the deformity of the ground, it can't really be done.
Thank you so much for your advice. I was feeling pretty dumb struggling with this question and I'm glad to know at least that it is complicated.
Bob S
Can you explain how did you get this relation- a=g*h/x ?
I think you are talking about drop testing on a rig as opposed to the sort you might use for key fobs for example. Drop rigs are used for components that are fitted to other assemblies and usually at specific accelerations in each axis and fixing the test sample in place with fixtures representative of those in the assembly. Go on, stop us guessing, tell us what this is and what testing you are wanting to carry out and why, it will give you more focussed feedback, and stop the answers heading in the wrong direction.
F=ma
F=8894N
If you don't mind my asking... I am a physics student and i have never heard of impact being measured in g. (I may be wrong) I'm going to run the scenario through my professor and get back to you on that.
  • · Replies 46 ·
  • · Replies 26 ·
10K
