Acceleration vs. mass (kg) graph
The discussion focuses on the relationship between acceleration and mass in physics, specifically in the context of an acceleration vs. mass (kg) graph. It establishes that the best fit line intersects the origin, indicating that when the sum of masses is zero, the acceleration becomes mathematically undefined. The conversation also highlights the implications of plotting inverse mass, where the y-intercept suggests infinite mass, which cannot be moved by finite force. Additionally, it references the Atwood machine experiment, emphasizing the importance of accounting for the effective mass of a non-ideal pulley in calculations of acceleration.
  • Understanding of Newton's laws of motion
  • Familiarity with the Atwood machine setup
  • Knowledge of graphing techniques in physics
  • Basic concepts of mass and acceleration relationships
  • Study the mathematical derivation of acceleration in the Atwood machine experiment
  • Learn about the effects of pulley moment of inertia on system dynamics
  • Explore the implications of non-ideal systems in classical mechanics
  • Investigate the concept of effective mass in various mechanical systems
Physics students, educators, and anyone interested in understanding the dynamics of mass and acceleration in mechanical systems, particularly in experimental setups like the Atwood machine.
L²Cc
If in an acceleration vs. mass (kg) graph (where the x-axis reads (1/m1+m2), the inverse of the sum of masses), the best fit does interesect with the origin because if x = zero, or (1/m1+m2) = o, the final solution is unreal since it is mathematically incorrect to divide one by zero.
Likewise, in an acceleration vs. differences of masses, best interesects with origin since when m1-m2=0, acceleration, as as result, equals to zero.
Finally, would it be correct to stay that the y interest of an acceleration vs. mass graph represents the acceleration of the system when 0 masses are involved, or does it repersent the gravitational mass (resistance)?
If you plot the inverse mass then the y intercept correspond to infinite mass, which can't be moved with a finite force. No gravity involved (unless it's providing the force being studied).
It looks like you are describing an Atwood machine experiment in which the acceleration is $$a=\frac{m_2-m_1}{m_2+m_1}g=\frac{\Delta M}{M}g.$$The usual procedure is to keep the total mass ##M## constant and move some mass from one side to the other to vary ##\Delta M##. Then a plot of acceleration vs. ##\Delta M## has slope ##g/M## from which one can deduce the acceleration of gravity.
This is the the case when the pulley is massless which never happens. A real pulley with moment of inertia ##I## and radius ##R## has effective mass ##m_{eff}=I/R^2## in which case the measured acceleration is $$a=\frac{\Delta M}{M+m_{eff}}g\approx \frac{\Delta M}{M}\left(1-\frac{m_{eff}}{M}\right)g.$$In the non-ideal pulley case, there is an intercept which can be used to find the effective mass.
  • · Replies 17 ·
  • · Replies 33 ·
  • · Replies 97 ·
16K
