How Do You Prepare a 40 L Phosphate Buffer with pH 6.9?
  • Thread starter Thread starter Eshi
    Buffer Reactions
To prepare 40 L of a 0.0500 M phosphate buffer at pH 6.9 using 1 M solutions of KH2PO4 and K2HPO4, the ratio of the concentrations of the acid (HA) and base (A-) must be calculated using the Henderson-Hasselbalch equation. The required ratio is 0.50, indicating that the concentration of HA should be double that of A-. This results in needing 2 L of HA and 0.66 L of A- for a total of 2.66 L of buffer solution. The remaining volume to reach 40 L should be filled with water, which amounts to 37.34 L. There are concerns about the calculations, specifically regarding the total volume and the correct ratio of HA to A-.
Eshi
Describe the preparation of 40 L of 0.0500M phosphate buffer, pH 6.9 starting with 1M solutions of KH2PO4 and K2HPO4. pKa= 7.2
pH= pKa + log[A-]/[HA]3. The Attempt at a Solution [/b
6.9=7.2 + log[A-]/[HA]
-0.3= log[A-]/[HA]
[A-]/[HA]= 0.50
0.5[HA]= [A-]
0.5[HA]+1[A-] = 1.5
0.5/1.5 = 0.33 = 33% [HA]0.05 mol/L x 40L = 2 mol HA
2 mol x 1L/mol = 2L HA2 mol x 0.33= 0.66 mol A-
0.66 mol x 1L/mol = 0.66 L A-2L HA + 0.66L A- = 2.66 <---Edit: 2.66 L of acid/base
40L-2.66L= add 37.34 L water to make the 40L total.
I was told by someone that this solution is incorrect. Any suggestions why?
Earlier you wrote you need 2 moles, here you have 2.66.
Not that I am sure I understand precisely your working in other places.
In the equation pH=pKa+log[A]/[HA], the ratio of the log value must be 10^-3=.5. Therefore, [HA] must be double [A].
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
