Action invariance under galilean boost
2 replies · 4K views · last reply
Petraa
Hello,
I've been spending a lot of time trying to solve this problem but I can't figure out a good solution.
I have to show that the action of a non-relativistic particle ( Schrödinger density Lagrangian ) is invariant under Galilean boost with the form
ψ(x0,x)→ψ'(x0,x)=eimvx-(im/2)x0v2ψ(x0,x-vx0)
x0= t
I've tried to find the transformed Lagrangian by replacing the wave functions and the derivatives but I'm not sure I did it correctly because I get monstrous expressions
I'm using this density Lagrangian L= ihψ*[itex]\partial[/itex]0ψ+h2/2m([itex]\partial[/itex]iψ*)([itex]\partial[/itex]iψ)
If someone can give me a good tip I'll appreciate it
thank you!
Ok, hints only, because this is an assignment.
Important fact: Lagrangians are not unique. You can freely add a total divergence to a Lagrangian without changing the equations of motion. And in this example the Lagrangian will not be invariant under the transformation, you will need to add a total divergence.
Let φ(x,t) be the phase factor in front you've added. You'll get three types of terms:
φ*φ x (derivatives on ψ) + ψ*ψ x (derivatives on φ) + (derivatives on both φ and ψ)
The first two types are easily handled. :smile: For terms of the third type you'll need to split off a total divergence, e.g. by throwing derivatives of ψ over onto derivatives of φ.
I've tried some, the "best" total divergence I've found is ∂i(ψ*φ*∂iψφ)
Fits all the terms on the equation but ( obviously ) φ*∂0φ and also leaves me a term ∂iψ∂iψ* that doesn't appear on the L'
I'm close to the solution ?
