Add Short Ints: 30064 + 30064 = -60128
  • Thread starter Thread starter Lightf
    Integers Short
The discussion revolves around the calculation of the sum of two short integers, specifically the expression 30064 + 30064, and the interpretation of the result in the context of short integer representation in programming languages like C or C++. Participants explore how the conversion to hexadecimal and the properties of short integers lead to a negative result.
  • Homework-related
  • One participant describes their process of converting 30064 to hexadecimal (7570) and adding it to itself, resulting in eae0, but expresses confusion about obtaining a negative result.
  • Another participant clarifies that short integers in C or C++ are signed, with the highest order bit indicating negativity, and explains that adding values can lead to overflow, resulting in negative numbers.
  • A different participant proposes a calculation involving the maximum positive short int (7fff) and suggests a method to derive a negative value (-151f) from the hexadecimal result.
  • One participant mentions the binary representation of eae0 and notes that the leading bit indicates it is a negative number, suggesting a value of -27360.
Participants do not reach a consensus on the correct interpretation or calculation method, with differing views on how to arrive at the negative result from the addition of the short integers.
There is an implicit assumption regarding the handling of overflow in short integer arithmetic, and the discussion does not resolve how to consistently apply the two's complement method for these calculations.
Lightf
The question is :
Converting to short int, calculate 30064 + 30064 as short integers.
Convert the answer to decimal ( the answer will be negative ).
None.
I converted 30064 to hex getting 7570.
I then added that to itself getting eae0.
But when i convert that back to dec I just get 60128 ? How am i suppose to get a negative number?
Lightf said:
The question is :
None.
Since you're talking about short integers, I'm assuming you are talking about the short int data type in C or C++. Short ints are 32 bit signed numbers, which means that the largest positive short int is 32,767, or 0x7ffff. Adding 1 to this gives you 0x8000, which is -32,768.
Any short int whose highest order bit is 1 is considered to be negative.
So the answer would be :
7fff - eae0 = 6ae1
6ae1 - 8000 = -151f
which is -5497 in dec.
Is that the correct way of doing it? Thanks for the help.
You may want to look for "two's complement" in your textbook or on the net.
So eae0 is 1110101011100000 but the first 1 just means its a minus number so its -27360
  • · Replies 19 ·
  • · Replies 20 ·
26K
