ADM: how to see the normal vector proportional to a 1-form?
The discussion centers on understanding how to represent the normal vector in the ADM formalism as a 1-form. The participants clarify that the normal vector, denoted as \( n_\mu \), can be expressed in terms of the Levi-Civita symbol and basis 1-forms, specifically \( n_\mu = \epsilon_{\mu\nu\lambda\sigma} a^\nu b^\lambda c^\sigma \mathrm{dx}^\mu \). They emphasize the importance of index notation, where upper indices represent n-tensors and lower indices denote n-forms, ultimately concluding that the normal vector can indeed be viewed as a 1-form through appropriate contraction with the Levi-Civita symbol.
  • Understanding of ADM formalism in general relativity
  • Familiarity with tensor notation and index conventions
  • Knowledge of the Levi-Civita symbol and its properties
  • Basic concepts of differential forms and their applications
  • Study the properties of the Levi-Civita symbol in tensor calculus
  • Learn about the contraction of tensors and forms in differential geometry
  • Explore the ADM formalism in detail, focusing on its applications in general relativity
  • Investigate the relationship between tensors and forms, particularly in the context of Lorentz invariance
This discussion is beneficial for physicists, mathematicians, and students studying general relativity, particularly those interested in the ADM formalism and the mathematical underpinnings of differential forms and tensor analysis.
symplectic
Hi
In the ADM formalsim, we need at some point to see the normal vector (to the 3D surfaces) as a 1-form.
How can we (simply) see that? (Please no Frobenius theorem, otherwise, with more explanation about this theorem)
No idea!
Consider this kind of object:
nνναβγaαbβcγ
where n is perpendicular to the hyperplane that contains a,b,c.
nνναβγaαbβcγ
Okey, and how can I see it as a 1-form?!
It has a lower index. The convention that I learned is that upper indices are n-tensor indices, and lower indices are n-form indices. You can reverse this convention if you like. The main point is that the three sets of coefficients on the RHS that contract with the Levi-Civita symbol are 1-tensors, and their indices are in the opposite position to the coefficient on the LHS, which is a 1-form (coefficient).
Maybe I don't know what you mean by "see it as a 1-form". If so, I appologize for the distraction. In the language of MTW, when a 1-tensor is contracted with a 1-form, the result sort-of tells you how many 1-form "surfaces" are pieced by the 1-tensor. In that description, the 1-tensor (coeffients with upper index) is sort-of a line, and the 1-form (coefficients with lower index) is sort-of a series of surfaces.
Thank you turin,
Yes, I guess that this is a manner to see it but ... I wonder how to do if there were no convention!
I still wait an answer which convince me :wink:
Writing it out in full, you would have
\mathbf{n} = n_\mu \mathrm{dx}^\mu = \epsilon_{\mu\nu\lambda\sigma} a^\nu b^\lambda c^\sigma \mathrm{dx}^\mu
where \mathrm{dx}^\mu are the basis 1-forms. Beyond that, I also don't know what you mean by "see it as a 1-form".
Hi againe,
OK, here is what I found in almost all papers that I read:
We have a 3d surface ∑ embedded in a 4d space M via the embedding Xt defined by:
Xt(x) = X(t,x) where X is a diffeomorphism X : σ x ℝ → M (x are coordinates on ∑ and X are those of M) so one can think about the surface as defined by : f(X) = t = constant so that:
0 = limε→0 [f (Xt (x + εb) − f (Xt (x))]/ε = baXμ,a(f)|X = Xt(x) for any tangential b of σ = X(∑) on x ... so that on can see n as : nμ = F f (a 1-form)
My problem is that I don't understand very well what we mean by all that !
symplectic, I think you missed my point. The convention does not matter. The RHS has 1-tensor coefficients, and the LHS has a 1-form coefficient. The only reason that I mentioned the convention was to clarify that the position of the index tells you that it is a 1-form.
Here's a different (more explicit) way to look at it. A 3-surface is basically a volume. A differential "area" of the 3-surface would have the form dxdydz, right. So, generalize these differentials to 1-tensors: dxαdyβdzγ, where these differentials are some specific directions in space-time. This product has units of 3-surface area (volume), but it is a 3-tensor, not a 1-form. You convert it to a 1-form by contracting with the Levi-Civita symbol. This is similar to converting a 1-tensor to a 1-form by contracting with the metric.
I don't know if this is standard notation, but, instead of using indices, imagine that the Levi-Civita symbol is a function that "eats" n-tensors and spits out (4-n)-forms.
ε(⋅,⋅,⋅,⋅)
So, in this case, the Levi-Civita symbol "eats" three 1-tensors, dx, dy, and dz.
ε(⋅,dx,dy,dz)=~dV
The tilde in front is my way to identify the object as a n-form. 1 argument of the Levi-Civita symbol is left open, so the result is a 1-form.
This is similar to the idea of the metric "eating" an n-tensor, resulting in a (2-n)-form.
η(⋅,⋅)
So, if the metric "eats" a vector (1-tensor), the result is a 1-form.
η(⋅,dx)=~dx
In the index approach, this is called "lowering" the index.
One more point to make: ε(dt,dx,dy,dz) is Lorentz invariant. This is true regardless of what dt, dx, dy, and dz represent, as long as they are 1-tensors.
ε(⋅,⋅,⋅,⋅)
ε(⋅,dx,dy,dz)=~dV
η(⋅,⋅)
η(⋅,dx)=~dx
Okey, you succeeded ... I don't see it anymore as a vector :smile:
If I understood, writing n as :
nμ = εμνρσdxνdxρdxσ
Tells us that it is in fact a 1-form, and not a vector !
  • · Replies 73 ·
