Max Acceleration in Linearly Varying Speed: Solving for a0 and K
The discussion focuses on determining the maximum acceleration of a vehicle that accelerates from rest to specified speeds under the assumption of linearly varying acceleration. The equation a(v) = a0 + Kv is central to the problem, where a0 represents the initial acceleration and K is a constant. The user is prompted to apply the relationship dv/dt = a0 + Kv to solve for the maximum acceleration at the given speeds of 50 mph and 65 mph. The conversation emphasizes the need to integrate the acceleration function to find the maximum values. Ultimately, the goal is to accurately calculate the maximum acceleration for both scenarios.
civeng999
The driver of a vehicle on a level road determined that she could increase her speed from rest to 50 mph in 35 sec and from rest to 65 mph in 95 sec. Assume that acceleration varies linearly with speed (with a non zero intercept). Determine the max acceleration in each case.
a(v) = a0 + Kv
a(0) = a0
a(vmax) = amax
Ok, so a(v)=dv/dt. You forgot that equation. Can you solve dv/dt=a0+Kv?
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
