Air pressure question for two different water columns
  • Level: Undergrad
  • Thread starter Thread starter Colin Wilson
    Pressure Volume
2 replies · 1K views · last reply
Colin Wilson
If you had pressure sensors (red) inside closed containers (black). The one on the left having more air volume than the one on the right. They are inside a bucket (green) that is filled with water. The water will rise higher in the left container. Will the pressure sensor readings be identical or will the right one read higher?
Diagram of two sealed tubes, each with a red pressure sensor at its top, standing open-end-down in a green-walled tank of water; the left tube has more trapped air and its water level is lower than the right tube's.
The right pressure sensor will read a higher pressure.
It is able to push water further downwards than the sensor on the left.
