Altering the odor of paint thinners
  • Thread starter Thread starter samtk
    Paint
The forum discussion centers on methods to alter the odor of paint thinners without changing their chemical composition. Users suggest that adding concentrated fragrances may not effectively mask the original smell due to the presence of volatile compounds. Instead, they recommend purchasing "odorless thinner," which is produced through fractional distillation to remove these volatiles. Safety concerns regarding boiling paint thinner are emphasized, with advice to avoid improvised distillation methods at home due to the risk of ignition.
  • Understanding of fractional distillation techniques
  • Knowledge of volatile organic compounds (VOCs)
  • Familiarity with the properties of paint thinners and solvents
  • Basic safety protocols for handling flammable materials
  • Research the process of fractional distillation in detail
  • Explore the chemical composition of common paint thinners
  • Investigate safer alternatives to traditional paint thinners
  • Learn about the properties and uses of low-odor turpentine
This discussion is beneficial for chemistry students, DIY enthusiasts, and anyone involved in paint formulation or solvent safety. It provides insights into safe practices and effective methods for altering solvent odors.
samtk
Hi all ,
Does anyone know what the best and cheapest way to alter the smell of paint thinners . I would assume adding a concentrated fragrance that would evaporate would do the trick . Please advise ?Thanks
Chemistry news on Phys.org
Adding new stinky volatile chemicals would certainly double the stink.
But not "remove" the first odor of still-present volatile compounds that will still be present, still evaporating from your unchanged paint thinner.
Covering up- let us say- fecal odors is pretty difficult too.
Why not purchase "odorless thinner" which is non-stinky paint thinner (a hydrocarbon only solvent) that as been distilled to remove the volatiles, in the traditional manner?
Thus they don't ADD stuff, they boil off the stinky volatiles: This ancient process is called fractional distillation. Look it up.
Thanks for the info . My daughter has this small chemistry project to do over summer and the idea is that she wants to change the smell of the thinner (ie not to smell at all like thinners ) without changing the composition . As for boiling it it can be done but iam worried to deal with such a volitale material .
Your advise is appreciated
Boil the stinky solvent in open air, in a closed container, vented only with a metal (copper?) 1/2 inch diameter vertical tube 2 feet tall, with a long 100 degree bent end 2 feet long at the top. Use an electric plate-type heater which will be quite safe. The boiling solvent will "reflux" in the vertical tube, allowing only the most volatile compounds to distill off. Put a cloth rag with ice or cold water on your new "downspout" and you will collect the condensed stinky volatiles in a glass jar.
Or you could make moonshine like this...it's the thousand-year old way to make whiskey. That is a fact, not a joke.
If the Ancient Romans had known how to do this, the Roman Empire may have lasted much longer than it did. All of the Roman rulers drank concentrated wine boiled down in lead containers. But wine dissolves lead salts, and this boiled wine was poisonous, causing many Romans to become crazy, with strange self-destructive behavior. Like Emperor Nero!
This is a great research topic for a science project as well as true detective-history.
All children should be exposed to science this way!
Thanks for the info . Can you advice at what temperature to boil the thinner in order to evaporate the stink ??
My other question this boiling will not alter the chemical composition on the thinners ??
Thanks
I don't know what the mixture is in the thinner! Boil it to find out. If it is like jet fuel (most likely) maybe 130 degrees F. Use a thermometer, stick it down a straight vertical tube near the top. When the vapors start to come out the top. look at the thermometer.
Distillers use a T-top there so you can read the thermometer. Do Distill until the temperature goes up- say 10 degrees. Then stop take away the heat. cool. Smell the pot...
The little bit of odorous material you smell is so tiny, it cannot hurt you. Like, pumping gasoline at the gas station.
99% of the solvent is hydrocarbons, straight and branched chain molecules. Like jet fuel.
Removing a little bit of aldehydes or ketones does not affect the composition. Itis like washing your underarms to remove stinky chemicals does NOT change your body composition.
I'd be very cautious about advising anyone to boil something as flammable as paint thinner. Even in the absence of a naked flame, there are dangers of ignition. The spark from an electric switch, static electricity or even a spark when something is accidently dropped onto stone or concrete could be enough to ignite the fumes. Just too risky all together.
There is a whole science to distillation. That is why I said you must condense the distilling vapors by cooling-- back to liquid, then catch the liquid distillate in a container. One can distill ethyl alcohol or gasoline this way safely. I have done it with n-hexane, a highly flammable solvent, in my laboratory hundreds of times. One does NOT blow flammable vapors into an open flame or spark source.
OP is apparently asking for a school kid who will be doing this at home. Way too risky.
I have a suggestion as I wana lessen the risk of my daughter distlling the thinner . As she is required to change the smell of the thinner if she adds liquid scents into the mixture will the inherent smell of the fumes of the thinners alter ? . The idea is that the thinner does not smell like a thinner without altering the effectiveness . Guys any ideas or suggestions??
Why not try it and judge for yourself? It's easy enough to try; the two might not even mix. In any case, I doubt that people would be fooled, and those of us who are allergic to many of the cheap scents would prefer the fumes of thinner by itself any day.
Besides the ordinary turps, there is a low-odor turps available at a higher price. Presumably it contains a different fraction, less odorous, but just as effective at dissolving organics. (Turps is close enough to paint thinner for our purposes.)
I wondered whether it might be possible to perform an experiment similar to evaporation or distillation, but using water-soluble and much safer reagents. Something like an analog demonstration. But none come to mind.
Science offers such a breadth of scope for experiments, that I think your daughter should be encouraged to look at other topics to experiment with, something guaranteed to be safe. I would never consider boiling paint thinner using improvised apparatus in my home (or garage).
15K
  • · Replies 131 ·
10K
  • · Replies 18 ·
  • · Replies 21 ·
