Alternator on a long transmission line
Connecting an alternator to a long transmission line with high capacitance can be dangerous due to the potential for increased voltage and current demands. Specifically, a quarter wavelength of open circuit transmission line can appear as a short circuit, particularly at 50 or 60 Hz. The high capacitance results in a leading power factor, which can cause the stator magnetomotive force (MMF) to reinforce the rotor MMF, leading to dangerously high voltage levels. Additionally, even isolated lines may still present lethal voltages, posing significant safety risks.
  • Understanding of transmission line theory
  • Knowledge of power factor concepts
  • Familiarity with alternator operation and characteristics
  • Basic electrical safety protocols
  • Research the effects of capacitance on transmission line performance
  • Study the relationship between power factor and alternator efficiency
  • Learn about the design and safety considerations for long transmission lines
  • Explore methods for measuring and mitigating high voltage risks in electrical systems
Electrical engineers, power system designers, safety professionals, and anyone involved in the operation or design of alternators and transmission lines.
samieee
Could it be dangerous to connect an alternator to a long transmission line,if the line has high capacitance?if dangerous then why? please explain...
How long, what frequency and what operating power?
If you connect a quarter wavelength of open circuit transmission line to your alternator, then it will look like a short circuit. This is only relevant for very long transmission lines (trans continental style) at 60 or 50 Hz.
A 'short' / regular length of transmission line will be, effectively, a capacitor, with a value of a few tens of pF per metre of line. This will affect the Power Factor of the load seen by the alternator. You would need to know what PF the particular alternator can cope with and at what output power.
The problem is that, to deliver a given Power, a PF which is less than unity (1) will require more current for a given voltage than the 'Power =Volts times Amps' would suggest. This is because the capacitor will need to charge and discharge, requiring current to flow in addition to the current in the (resistive) load. This current is not in phase with the voltage so there is no 'useful power' involved - just extra current handling demand on the cables and alternator windings.
What is the context of your question? What kind of alternator? Is this for schoolwork?
I didn't realize this thread was started by samieee when I posted a reply to their thread asking about https://www.physicsforums.com/showthread.php?p=2601746#post2601746". Hopefully they will realize it is not a trivial process.
any kind of alternator,any frequency (let assume it as supply frequency).Any way i got the answer,the anser is :It is dangerous,because at high capacitance(leading power factor) the stator MMF will aid the rotor MMF thus the voltage will increase at large magnitude.which is not desired.
One of the problems with long transmission lines and capacitance is that even if the line is isolated there is the posibility of lethal voltages still being present in the lines. Put into circuit Earth and prove dead.
  • · Replies 21 ·
