ALU status register carry equation
garr6120
I was wondering what the carry (C) equation for the logic gates would be in an ALU status register?
I originally thought that it was C equals the last carry output. However, my colleagues tell me its C equals to the sum of the last bit primed AND the last carry output.
Can someone clarify my misconception if I am wrong?
You mean how carry is set if the ALU performs OR, AND or similar operations? It will depend on the ALU, I don't think it makes sense to use the carry bit from these operations.
I mean when the ALU uses arithmetic sorry.
What does this mean? You get a potential carry output bit set if the result of the add generates an overflow/carry in the target register. How can it be dependent on a previous operation?
Can you give an example of the Assembly code you have in mind, and mention a potential ALU that we can use to answer the question?
For example...
http://www.learnabout-electronics.org/Digital/images/ALU-logisim.gif
There, carry is simply the next bit after the largest bit the ALU regularly has. If you want to add 1100 0000 + 0110 0000 the result is 1 0010 0000, but an 8-bit ALU can only show 0010 0000, the remaining bit is treated as carry.
