Ammeter to help the circuit work
The discussion centers on troubleshooting an IC circuit connected to a motor from a remote control car, specifically involving the use of an ammeter and resistors. The user initially connected a 9V power supply but faced issues until an ammeter was placed in parallel with a resistor in series with the motor. The IC chip model mentioned is SDRX2BD, which contains 18 resistors, 9 inductors, and 11 capacitors. Participants emphasized the importance of understanding current flow, resistance, and the implications of using an ammeter in parallel with resistors to avoid overheating components.
  • Understanding of basic circuit theory, including series and parallel configurations.
  • Familiarity with ammeter usage and its impact on circuit resistance.
  • Knowledge of the SDRX2BD IC chip specifications and functionality.
  • Experience with troubleshooting electronic circuits and heat management.
  • Research the specifications and operational characteristics of the SDRX2BD IC chip.
  • Learn about the principles of current flow and resistance in parallel circuits.
  • Investigate methods for managing heat dissipation in electronic components.
  • Explore the role of damper diodes in motor circuits to prevent back EMF damage.
Electronics enthusiasts, hobbyists working with remote control vehicles, and engineers troubleshooting motor control circuits will benefit from this discussion.
lmkjason
Ammeter to help the circuit work!
I have connected one IC circuit which is taking from a remote control car. Then I connect it to the a power supply which is 9V. It doesn't work in the beginning. But I don't know why it works after I connect an ammeter in parallel to the resistor which in in series to the motor. The circuit diagram is attached. I have tried to use a variable resistor to instead of the 4k7 ohm resistor and remove the ammeter. But the circuit doesn't work. Do I need to use a capacitor to stablize the current flow into the motor. Or I need to add another amplifier to increase the current input into the motor. But I think it is quite dangerrous to add a amplifier directly in series with the motor since it may burst. Also, do I need to add an inductor to store the energy. Thank you for any help for that.
Where's the motor in your diagram?
Why do you have an ammeter connected in parallel instead of series?
What is the IC chip supposed to be doing?
An ammeter has close to zero ohms resistance.
If it works this way without burning anything out then you either do not need the 4k resistor or it should be a very much smaller value.
The motor is connected in series of the switch. I have tried 500 ohms resistor insteads of the 4k7 ohm resistor. However, the resistor starts to heat up to an unacceptable level in a short time. Hence, I change it to 1k ohms. This doesn't move again in this case. I don't try less than 100 ohms since I think it will burn the IC circuit. I have burnt one IC circuit when I connect it directly without any resistor in the circuit to reduce the current.
The IC chip is a complicated circuit which I don't know how to draw it. The chip model is SDRX2BD and there is code of B 60200397. It has 18 resistors, 9 inductors and 11 capacitors in the IC circuit. If it is necessary, I can draw it in the spice software. But I really don't how to draw it in the photoshop. Thanks for any help for the circuit. I really appreciate the reply of the message.
Before or after the IC chip?
Can you draw the circuit as it is actually connected? That makes troubleshooting a lot easier!
How much current can the IC source?
How much current does the motor draw direct with no IC?
What are the heatsink requirements for the IC?
Are you using a damper diode on the motor?
i should assume that the current is bypassing the resistor and going straight through the ammeter and taking the path of least resistance (as electricity does).
the idea of a resistor is tho provide resistance(duh) to lower your current so if you have a large current and you add any resistor you should expect energy loss in the form of heat, more resistance, more heat. that is afterall how they work, converting electrical energy to heat energy(at least that's how the old wire resistors worked). the resistor in parallel to your ammeter adds more capacitance to your "wire" and has the opposite effect of a resistor. why this already does not cause your circuit to overheat, if it is from a 500ohm resistor, i do not know...
if you can't figure out what to do i suggest you make that ammeter a permanent fixture of your circuit and (possibly) remove the resistor with it in place. the ammeter itself is a resistor,just not anywhere near as strong.
Please do not add confusion to this discussion. This makes no sense.
its like placing 2 resistors in parallel, where Rt=1/R1+1/R2. the ammeter also acts as a resistor in this case(just not a very strong one). decreasing your total resistance means you are increasing the capacitance of the "wire". electricity flows easier through wire with less resistance and higher capacitance as it allows for a higher current.
i am referring to the parallel resistor and ammeter as the wire. i use the term wire because it is easy to understand how a thin wire has more resistance and a thick wire has less resistance.
It has nothing to do with capacitance. I think you mean current carrying capacity/ability, or what is referred to as ampacity.
well yes, that's what i mean... i don't mean capacitance like farads
AMPACITY IT IS!
Lmkjason, just replace thae word capacitance with the word ampacitance in what i said and perhaps it will help you find a soloution...
  • · Replies 20 ·
  • · Replies 17 ·
26K
