Amplitude and Natural Frequency of an Unbalanced Motor System
  • Thread starter Thread starter bikramjit das
The discussion focuses on calculating the amplitude of vibration and natural frequency of a beam carrying an unbalanced motor operating at speeds of 120 to 150 RPM. The key formula for amplitude is derived from the concept of whirling shafts, specifically using the equation y = e / ((Wn / W)^2 - 1). Participants emphasize the importance of understanding forced simple harmonic motion (SHM) and the conditions under which the mass loses contact with the oscillating beam. The differential equation for sinusoidally driven SHM is also highlighted as crucial for solving the problem.
  • Understanding of simple harmonic motion (SHM)
  • Familiarity with differential equations in mechanical systems
  • Knowledge of whirling shafts and their dynamics
  • Basic concepts of vibration analysis in mechanical engineering
  • Study the differential equation for sinusoidally driven SHM
  • Research the conditions for mass loss of contact in oscillating systems
  • Explore the effects of motor imbalance on vibration amplitude
  • Learn about the natural frequency calculation for mechanical systems
Mechanical engineers, students studying dynamics, and anyone involved in vibration analysis or motor system design will benefit from this discussion.
bikramjit das
Question:There is a fixed end beam PQ. It is carrying a motor M. The motor is unbalanced and when the motor is rotating ,it is making the beam to vibrate with a frequency equal to the speed of the motor. A small mass is kept at point A just above the motor on the beam. it also goes up & down along with the beam . When the motor speed is 120 - 150rpm, the object at A is loosing contact with the beam & is actually dancing on the beam. Determine the amplitude of vibration when the speed of motor is 120 rpm and when 150 rpm . Then calculate the natural frequency of the system.
What have you tried or thought about so far?
I think I can put the concept of whirling shaft in it... so I put the formula for amplitude as , y=e / (_{}Wn / _{}W )^2 -1
pls help me and tell whether it is correct or not
I don't know if your approach can achieve results. When I see a vibrating beam I tend to think of simple harmonic motion (SHM). And a beam that's being driven by a motor (sine function) would be forced SHM.
so, in this kind of forced SHM , what will be the eqn of motion?? pls try to do this question once.. I have been trying it from many days
The forum rules don't allow direct answering of problems. The idea is to give just enough help so that the problem poser can solve it him/herself.
That said, all SHM has a single form of differential equation. The solutions tend to be sinusoidal in nature. Have a look at the http://en.wikipedia.org/wiki/Harmonic_oscillator" .
You're going to want to think about under what conditions, given SHM, the mass will just begin to lose touch with the oscillating beam.
this link didn't helped at all sir... pls give the diff eqn at least
The differential equation for the sinusoidally driven SHM is given in the link in the section, "Sinusoidal driving force".
The problem seems to need more description, doesn't it? Like the mass that the motor is spinning, the stiffness and length of the shaft, and so on. SHM usually deals with spring forces and masses.
You also need more mechanical details about the motor and how it attaches to the stationary shaft. Why would it start to dance on the beam? What is physically separating?
Can you scan the problem drawing from your assignment?
And as gneill correctly points out, we will not be doing your work for you on this. We are happy to try to help you figure out how to solve the problem, though.
EDIT -- Oh, maybe they are saying that the mass is just resting on the top of the beam, and they want to know when the mass loses contact with the beam as it oscillates in its fundamental mode. That may simplify the problem a bit, but I'm not sure how much.
  • · Replies 21 ·
