Amplitude of a simple harmonic motion equation
The discussion focuses on calculating the amplitude of a simple harmonic motion (SHM) using the equation x(t) = Acos(ωt + ϕ). Given a 200 g block attached to a spring with a spring constant of 10 N/m, the initial conditions include a displacement of 20 cm below equilibrium and an upward velocity of 100 cm/s at t = 0s. The derived formula for amplitude is A = sqrt((x0)^2 + (v0/ω)^2), which is reached by squaring the velocity equation v = dx/dt = -Aωsin(ωt + φ) and simplifying. This method provides a clear pathway to determine amplitude in SHM scenarios.
  • Understanding of simple harmonic motion (SHM) principles
  • Familiarity with the equations of motion for oscillatory systems
  • Knowledge of spring constants and their role in SHM
  • Basic algebra for manipulating equations and solving for variables
  • Study the derivation of the velocity equation in simple harmonic motion
  • Learn about the relationship between spring constant and oscillation frequency
  • Explore the concept of phase angle (ϕ) in SHM and its effects on motion
  • Investigate energy conservation in simple harmonic oscillators
Students of physics, mechanical engineers, and anyone interested in understanding the dynamics of oscillatory systems and simple harmonic motion calculations.
nehcrow
if you have the equation: x(t) = Acos(ωt + ϕ)
and you have the following information: A 200 g block hangs from a spring with spring constant 10 N/m. At t = 0s the block is 20 cm below the equilibrium position and moving upward with a speed of 100 cm/s.
The answers give a short method of calculating the amplitude but I have no idea how the reached it, basically what they did was: A = sqrt((x0)^2 + (v0/ω)^2)
how did they reach that conclusion??
velocity v = dx/dt = -Aωsin(ωt + φ)
Square both the sides and simplify.
Thanks!
  • · Replies 51 ·
