Amplitudes of longitudinal sound waves
The discussion centers on the nature of longitudinal sound waves, specifically how to increase the amplitude of such waves without altering their wavelength. Participants explore the implications of amplitude changes on particle displacement and pressure within the medium, as well as the relationship between amplitude, frequency, and energy in sound waves.
  • One participant questions how amplitude can increase without affecting wavelength, suggesting that higher amplitude implies greater particle displacement and thus longer wavelengths.
  • Others argue that increased displacement does not necessarily correlate with wavelength changes, emphasizing that wavelength is determined by the distance between successive peaks, not the amplitude of displacement.
  • Some participants relate the concept to musical notes, explaining that a note can be played at different amplitudes without changing its frequency or wavelength.
  • A participant seeks clarification on how higher amplitude would visually manifest in an animation of sound waves, pondering whether it would affect the "thickness" of compression areas in the representation.
  • Another participant clarifies that pressure gradients, rather than thickness, increase with higher amplitude, indicating steeper pressure differences for louder sounds.
  • One participant introduces the concept of simple harmonic motion, suggesting that the displacement of particles in a medium is proportional to the force applied, and uses the example of a pendulum to illustrate that amplitude does not affect frequency.
Participants express disagreement regarding the relationship between amplitude and wavelength, with some asserting that amplitude does not affect wavelength while others initially suggest it does. The discussion remains unresolved on certain aspects, particularly regarding visual representations of amplitude changes.
Participants mention nonlinear effects that may arise at large displacements, indicating that the discussion primarily focuses on linear wave behavior. There are also references to specific examples and analogies that may not fully encompass the complexities of wave behavior.
This discussion may be of interest to students and enthusiasts of physics, particularly those exploring wave mechanics, sound propagation, and the properties of longitudinal waves.
TP9109
I'm coming back to physics after a long so apologies if this has a basic answer- How can the amplitude of a longitudinal sound wave be increased without increasing its wavelength? I understand what it would look like graphically if a low amplitude sine wave and high amplitude sine wave were representing this scenario (ie the two waves would have the same wavelength but their peaks and troughs would be displaced by different amounts from the equilibrium position showing the differences in amplitude like in graph below)
But how does that work in reality? When I imagine a longitudinal wave with higher amplitude I imagine it causing "more compression" of the particles of the medium and "more rarefaction" of the particles. Looking at just compression, wouldn't the particles have to "stray further" from their original rest position in order to move closer and collide more with the next particles in the line to achieve this higher compression (and thus higher pressure). Straying further from the original position though means a longer wavelength since a greater distance is traveled during the cycle of the wave. So the only other way I can think of the amplitude increasing whilst keeping a constant wavelength is if we make the wave carry more energy whilst stopping the particles from "straying further" from rest position? Is this energy in the form of heat maybe? Quite confused by this and have tried looking online for answers so any insight into this is appreciated!
Straying further from the equilibrium position does not imply a longer wavelength. At any moment there are many peaks at different distances from the source. The wavelength is determined by the distance between two successive peak displacements. The size of the displacement itself doesn’t matter.
Of course, if the displacements are large enough you will get dispersive and other nonlinear waves instead of nice linear ones, but that is a different topic.
no, that's incorrect and your diagram demonstrates that. the distance between any peak ( or trough)
is the same for the low amplitude as it is for the high amplitude.
Just as playing a single note on any musical instrument ... play a middle "c" it can be played loudly or softly
It's amplitude has changed, it's frequency, aka wavelength, hasn't
Dave
Thanks for your reply, that makes more sense now
Thanks for your reply, that makes more sense. So if we say that this animation represents that soft middle "c" note being played:
https://www.acs.psu.edu/drussell/Demos/waves/Lwave-Red-2.gif
I understand that the animation for the loud middle c would keep same frequency and wavelength but just its amplitude would change, but I'm struggling to visualise how that higher amplitude would appear in the animation? A higher amplitude would mean each compression "strip" area in the animation would contain more particles therefore more pressure- does that mean the "thickness" of the strips would be increased as more particles are involved in the compression? Or I guess another way is if strip thickness stays the same but with the particles having more energy than soft c? Thanks again
They don't have a specific "thickness", the pressure has a gradient, and for a louder sound the pressure difference and so the pressure gradient are steeper.
The peaks would be more concentrated for a higher amplitude wave.
Low amplitude:
High amplitude:
For a medium like air (or steel or water) the amount the particles are displaced is proportional to the force on them, This is the basis of simple harmonic motion. The best proof for you that amplitude doesn't affect frequency of oscillation is to look at the way a pendulum behaves.
You could do this yourself, easily. Make up a pendulum with a light string and an object with some reasonable mass (a fishing weight or a chunky steel nut). Measure the time for ten cycles of swing with a small displacement (say +/-5 degrees) and then for a larger displacement (+/-10 degrees) for those values you should find very little difference in the times - showing that the frequency doesn't change) This works despite the fact that a simple pendulum motion is not pure SHM.
  • · Replies 20 ·
  • · Replies 31 ·
