Does the Relation ##T_2 = T_1 e^{\mu \theta}## Hold for an Accelerating Capstan?
  • Thread starter Thread starter etotheipi
    Accelerating
The relation T_2 = T_1 e^{\mu \theta} holds for a massless rope around a pulley with friction, where T_1 and T_2 are tensions and μ is the coefficient of friction. The torque on the pulley due to friction is expressed as R(T_2 - T_1), and the net force on the pulley is derived from the tension components along the axis of symmetry. The discussion explores whether this relation is valid under conditions of acceleration for the rope or pulley. It concludes that the net force on any string element remains zero regardless of motion, confirming that the relation is always applicable for massless strings. Thus, no additional proof is necessary for the validity of the relation under these conditions.
etotheipi
For a massless rope wrapped around a pulley with friction, it can be shown via integrating over string elements that the tensions on either side of the pulley are related by ##T_2 = T_1 e^{\mu \theta}##, if ##\mu## is the coefficient of friction and ##\theta## is the angle subtended by the rope in contact with the pulley. Details on this derivation for the case where the system is in static equilibrium can be found here, under section 2.
It is subsequently possible to show that the torque on the pulley due to friction equals ##R(T_2 - T_1)## and the net force on the pulley due to the string equals the component of ##\vec{T}_1 + \vec{T}_2## in a direction along the axis of symmetry of these two forces.
I wondered if the relation ##T_2 = T_1 e^{\mu \theta}## could also be shown to be valid if the rope was instead accelerating around the pulley, or even if the pulley itself were undergoing translational acceleration (assuming it retains contact with the rope)? Or whether it no longer applies. Thank you!
I figured it out, the net force on any individual element of string must be zero regardless of the state of motion of the string, since the string element is massless. So this result holds always for massless strings, and no further proof is required.
Likes Lnewqban, vanhees71, anorlunda and 1 other person
  • · Replies 32 ·
  • · Replies 32 ·
9K
