An attempt to find the total differential of a two-variable function
  • Level: Undergrad
  • Thread starter Thread starter Kashmir
    Differential Function
6 replies · 2K views
Kashmir
Let ##\quad z=h(x, y)##
and
##x=f(t) ; y=g(t)##
Let the change in the function z be given by ##\Delta z=h(x+\Delta x, y+\Delta y)-h(x,y)##
We can also write the change as
##\begin{aligned} \Delta z=h &(x+\Delta x, y)-\\ & h(x, y)-h(x+\Delta x, y) \\ &+h(x+\Delta x, y+\Delta y) \end{aligned}####\Delta z=\Delta h_{y\text { constant }}+\Delta h_{x
\operatorname{constant} }##
In the limit then we have
##dz=\frac{\partial h}{\partial x} d x+\frac{\partial h}{\partial y} d y##
Is there anything wrong with this derivation?
What could possibly be wrong ? :rolleyes:
\operatorname{constant} }$$is not really clear
I've not seen this derivation, thought maybe it was wrong somehow.
The delta y constant means that y has been kept as a constant
Some amendment
[tex]\triangle z = \triangle h_{y\ constant}+\triangle h_{x+\triangle x \ constant}[/tex]
[tex]\triangle z = \triangle h_{x\ constant}+\triangle h_{y+\triangle y \ constant}[/tex]
For general paths
[tex]\triangle z = \int _{(x,y)}^{(x+\triangle x,y+\triangle y)} \nabla h \cdot \mathbf{dl}[/tex]
anuttarasammyak said:
Some amendment
For general paths
So am i wrong, friend?
The difference is magnitude of second order of infinitesimals so
dz=∂h∂xdx+∂h∂ydy
holds in the limit.
