Find the Gravity Center of an Egg: Boaz's Assignment
  • Context: High School
  • Thread starter Thread starter bobo
    Center Egg Gravity
The discussion revolves around finding the center of gravity of an egg, particularly in the context of an assignment that requires placing the egg on its center of gravity without human intervention. Participants explore various methods and ideas related to this problem.
  • Homework-related
  • Boaz seeks methods to find the center of gravity of an egg and suggests creating a mechanism for this purpose.
  • Nautica proposes spinning the egg like a top as a potential method.
  • Another participant suggests that simply letting the egg sit on a counter would suffice since the center of gravity is within the egg.
  • Boaz clarifies that the egg needs to be suspended in the air and placed on a small ball without human intervention.
  • A participant discusses suspending the egg by a thread to find its center of gravity, suggesting two hanging positions for accuracy.
  • Another idea involves placing the egg on a table and noting the point of contact to determine the center of gravity once the egg comes to rest.
  • A later reply suggests using a raw egg, marking the heavy side, and observing its behavior when spun to understand its center of gravity dynamics.
Participants present multiple competing views on how to determine the center of gravity of an egg, with no consensus reached on a single method.
Some methods depend on the assumptions about the egg's shape and mass distribution, and the effectiveness of each proposed method may vary based on these factors.
bobo
hello,
i have an assinment that requries puting an egg directly on it gravity center.
1. how can i find it`s gravity center?
2. do you think of and way that i could do it (maybe make some kind of pocket, of a machine?)
thanks,
Boaz
how about spinning it like a top?
Nautica
How about just letting it sit on the counter? The center of gravity is inside the egg, so, it is always "on its gravity center."
good ideads but...
the real problem that i need to take the egg that hangs in the air (connected to a sting) and put it directly on a small call that the center gravity will be in the middle (without human intervntion).
nautica suggests spinning the egg... but that wouldn't give you anything wud it? besides spinning's got more to do with center of mass (rotational motion). A way to find center of gravity is to suspend it by a thread (like someone mentioned) tied around the egg so that the egg hangs symmetrically about the circle formed by the thread around it. You do this 2 ways... first when the egg is hanging straight (the way they are kept in the box. Second way would be to hang it perpendicular to the previous position (the way it stays when you place it on the table). OK>>> that gives another idea... just place the egg on the table and it'll automatically rest on a point just below the center of gravity. Once the egg stops moving (upon placing it on the table), just note the point at which it's touching the table. The center of gravity will be just above that point half way to a diametrically opposite point.
Right good idea, spinning the egg.
But try this (using a raw egg). Let it first get into equilibrium resting on the table. Then turn it upside down, rotating it 180 degrees around the longitudinal axis (so don't put it neither on it's pointy end nor on its blunt end). Get a marker and put an x on the heavy top part. Now spin it and see what the x is doing. And we observate that contrary to a spinning top, the egg turns itself back, heavy side down, during the spinning.
  • · Replies 31 ·
  • · Replies 22 ·
