Understanding Pascal's Law: Why is Force Greater in One Cylinder Than the Other?
This discussion clarifies Pascal's Law, demonstrating that the force exerted in one cylinder can be greater than in another due to differing weights. Specifically, the forces in cases (a) and (c) are equal, while the force in case (b) is 1.6 times greater than in case (a) due to an 800 kg mass compared to a 500 kg mass. The relationship is established through the principle that pressure remains constant across connected fluid systems, leading to varying force outputs based on the weights applied.
  • Understanding of Pascal's Law
  • Basic knowledge of fluid mechanics
  • Familiarity with pressure and force calculations
  • Concept of hydraulic systems
  • Study the applications of Pascal's Law in hydraulic systems
  • Learn about pressure calculations in fluid mechanics
  • Explore the relationship between force, mass, and acceleration
  • Investigate real-world examples of hydraulic brakes
Students of physics, engineers working with hydraulic systems, and anyone interested in the practical applications of fluid mechanics will benefit from this discussion.
brotherbobby
Rank in order, from largest to smallest, the magnitudes of the forces, ##\vec{F}_a, \vec{F}_b## and ##\vec{F}_c## required to balance the masses (in kilograms) shown in the diagram below.
Pascal's law states that for a pair of cylinders of areas ##A_1## and ##A_2## "connected" over a fluid body and at the same height, the forces required to balance them are in direct proportion to the areas : ##\frac{F_1}{F_2} = \frac{A_1}{A_2}##.
Additionally, the pressure at a point in a fluid a distance ##d## below the surface is ##p = p_0 + \rho g d##, where ##p_0## is the pressure at the surface of the fluid which is usually atmospheric pressure : ##p_0 = p_{\text{atm}}## (usually)
Answer : Using Pascal's law, this is my answer : ##\color{blue}{\boxed{\vec F_a = \vec F_c < \vec F_b}}##.
Reasoning :
Forces ##F_a## and ##F_c## are equal because the pressures required at the two cylinders for case (c) is the same as that required in (a). It doesn't matter how many of those cylinders of liquid exist for the case (c) or (a). For as long as the masses (and therefore weights) on them remain the same, the same force would be necessary to keep the brakes (pistons) in place.
However, force ##F_a < F_b## using Pascal's law as stated above. The pressure to be generated by the force at the second cylinder in (b) is more than the same for (a) since a 800 kg mass is heavier than a 500 kg mass. This excess pressure at the second cylinder for (b) must be the same at the same level for the first cylinder. Hence the force exerted at the first cylinder has to be correspondingly greater at (b) than at (a).
Numerically, ##F_b = 1.6 F_a## since ##\frac{8}{5} = 1.6##.
Is my answer correct?
Sounds very good to me.
  • · Replies 23 ·
  • · Replies 31 ·
