An integration problem using trigonometric substitution
34 replies · 8K views · last reply
mech-eng said:
Now it seems that I can solve ##\sec^3\theta## hence I can solve the question. This is my result I have arrived at. Would you please check it?
##sec\theta=\frac {\sqrt {\frac13^2~+y^2}} {\frac13} ##
##\frac13\int sec^3\theta=\frac13 3\sqrt{{\frac13}^2+y^2}~~3y+\frac13 \frac12 ln |sec\theta+tan\theta|##
Substituting the values obtained and cancelling out,
##\frac13\int sec^3\theta=3\sqrt{\frac13^2+y^2}~~y+\frac16ln|\frac {\sqrt{\frac13^2+y^2}}{\frac13}|##
In the end, is this the solution?
P.S: When I asked this question, I thought this was a very straightforward and short question with a few easy steps.
Remember the integration constant C.
Here is what I get:##\frac{1}{3} \int sec^3(\theta) d\theta = \frac{1}{6} (9y \cdot \sqrt{(\frac{1}{3})^2 + y^2}## ##+ \ln \left|3 \big(\sqrt{(\frac{1}{3})^2 + y^2} + y) \right|)##+ C
You can check it for yourself: just differentiate the "answer" and see if it delivers the original integrand. This is something that you should get in the habit of doing, every time.
The original problem
##\int\sqrt{1+9y^2}dy##
can be solved without any substitution , just integrating by parts:
##\int{\sqrt{1+9y^2}(1)dy}=\sqrt{1+9y^2}y-\int{\frac {9y^2}{\sqrt{1+9y^2}}dy}##
Add and subtract 1 to the numerator of the fraction in the integral, it decomposes into two terms, one is the original integral, the other integral is a basic one. :smile:
I don't understand what you do here mostly because there is no fraction in the original problem. It is just a square root of square of an expression of y.
mech-eng said:
I don't understand what you do here mostly because there is no fraction in the original problem. It is just a square of an expression of y.
It is the integral in the second line.
