Analyzing an Electric Circuit: Finding Req with KVL and KCL
The discussion revolves around analyzing an electric circuit to determine the equivalent resistance (Req) using Kirchhoff's Voltage Law (KVL) and Kirchhoff's Current Law (KCL). The circuit includes various resistors and a voltage source, with specific values provided for some components.
  • The original poster attempts to identify loops and junctions in the circuit to apply KVL and KCL but expresses uncertainty about how to proceed with the equations. Some participants suggest visualizing the circuit differently to identify loops and recommend writing voltage equations. Others question the inclusion of the voltage source in the analysis and the implications of voltage drops across resistors.
Participants are actively engaging with the problem, offering guidance on labeling currents and structuring equations. There is recognition of the need for clearer definitions and organization of the circuit elements, but no consensus has been reached regarding the approach to take.
The original poster indicates a lack of familiarity with KVL and KCL, which may affect their ability to formulate the necessary equations. There are also indications of confusion regarding the relationships between the resistors and the voltage source in the circuit.
mikil100
[/B]
http://imgur.com/Kq5e4Ka This is the circuit I need to find the Req for, the only things given are the Voltage of 7.1, and the resistance of each circuit.
V=IR
Kirchhoffs laws, the KVL and KCL.
I have spent some time trying to solve this circuit, however I now realize that using circuits in parallel and in series is not an option due to the 2.3 ohm resistor, my instructor told me to use the KVL and KCL equations to solve, but I am unfamiliar with these as we haven't gone over them in class.
From what I have tried to do so far, I want to identify all of the loops ( which I didnt do in the picture to leave it easy to view), and all of the junctions to start the equations. I named resistors according to their Ohms.
There is a loop from the
11R, 2.1R, and 6.0R resistor,
11R,7.9R, and 7.7R
11R, 2.1R, 2.3R, and 7.7R
11R,7.9R,2.3R, 6R
There are junctions for
R11=R2.1+R7.9
R2.1=R2.3+R6.0
R7.9=R2.3+R7.7
And you can say R6.0+R7.7=R11 I believe
This is where I hit a wall... mathematically I am unsure where to proceed, I know that I have several unknowns and several equations, therefore meaning I need to solve by combination of equations, but when I try to do this I get mixed up with combining the equations and end up with many values I cannot solve for.
My goal is to find the current coming from the first circuit, and I believe from there for solution will become much easier.
Some people have mentioned using matrices but this is something completely unknown to me, so I believe algebra is the only option. Am I on the right path to solving this problem, so far?
If you take all the labels off the circuit and just make all the components into wires, do you see 3 rectangles (1 big on the left with 2 smaller next to it on the right) ? THOSE are what you should be using as loops. Draw current loops in each. Write the sum of the voltages around each loop and you will have 3 equations in 3 unknowns. Solve. Write it up neatly on your homework sheet. Go out for pizza.
So make 11R, 2.1R, 6.0R one loop for the left side and for the right two boxes
and for the left
2.1R, 2.3R 7.9R
2.3R, 6.0R 7.7R?
Uh ... you think maybe the voltage source should be included?
Sorry, I should have showed that.. 11R+2.1R+6.0R=7.1
I'm not sure the same can be said for the other two loops though?
Uh ... not sure WHAT can be said for the other two loops? That the voltage source be shown? Well it's not IN those loops is it?
Well.. yes but isn't the voltage for the two second loops going to be less due to the voltage drop from the first resistor?
and also I'm not seeing how I can get 3 unknowns... I would still have to worry about the 7.9 ohm resistor and 7.7ohm resistor
reread post #2. Carefully.
Before you can write equations you need something else: label the currents through each resistor. Like I1, I2, I3...
Both Kirchoff's rules include currents. So far you did not write meaningful equations. The currents will be the unknowns in the equations.
This is exactly what I told him to do in post #2 ... draw the current loops and write the voltage equations around the loops. Short of actually redrawing the figure and solving it for him, I don't see what other hints there are to give.
Sometimes you have to repeat the hints, until they go through. :)
  • · Replies 18 ·
