Angle between a force and radius?
The discussion focuses on calculating the work done by a force and the angle between the force vector and displacement vector in a physics problem. The force is given as F=(6i-2j) N and the displacement as deltaR=(3i+1j) m. The work done is calculated using the dot product, yielding W=16 J, while the angle is determined using the cosine formula, resulting in cos(theta) = 18/20. The confusion arises around the definitions of dot product and scalar product, as well as the relationship between work and angle.
  • Understanding of vector operations, specifically dot product and scalar product
  • Familiarity with Newton's laws of motion
  • Knowledge of trigonometric functions and their application in physics
  • Basic understanding of work-energy principles in physics
  • Study the concept of vector dot product in detail
  • Learn about work-energy theorem and its applications
  • Explore trigonometric identities and their use in physics problems
  • Investigate hydraulic systems and the principles of force transmission in fluids
Students studying physics, particularly those focusing on mechanics, as well as educators looking for examples of vector calculations and work-energy principles.
TexasCow
A force, F=(6i-2j)[N], moves a particle through a distance deltaR=(3i+1j)[m]
A. Find the work done on the particle
B. Find the angle between F and deltaR
W=F*D
A. F=Root(6^2+2^2)=6.32N
R=Root(3^2+1^2)=3.16m
W=FD=(6.32*3.16)=20.00N/M
I can't figure out B though. By the way, is my A correct? Thanks!
W=FD=(6.32*3.16)=20.00N/M It is true if they are in the same direction.
W= F.deltaR = (6i-2j).(3i+1j) = 18 - 2 = 16J
And angle is given by cos(theta) = F.d/FD
I'm kind of confused. Did you foil those out? I was taught to use pythag. theorum for component vectors. I'm also kind of confused on F.D/FD. What does this mean?
I think B can be found if you find the dot product of the two vectors...
In vector you can perform scalar product and vector product. If Fand D are the force and dispalcement vectors then the work done = F.D and angle between the vectors =F.D/FD Bold letters indicatre the vectors.
Oh, so the dot product is called the scalar product around here...
Oh I think I see what you're saying. So the scalar, or dot product divided by FD is equal to the angle?
Yes.
I think I just confused myself. You said W=F.D, or F multiplied by D. Then, you say that the angle is F.D/FD. If F.D is F multiplied by D, then wouldn't F.D/FD be 1? Since top and bottom would be the same? Or is the top the dot product and and bottom FxD?
Also, the dot product is:
lAl*lBlcosx correct?
F.D = 6i-2j).(3i+1j) = 18 - 2 = 16J It is dot product.
FD = FD=(6.32*3.16)=20.00N/M
And cosx = 18/20
radius
the diameter of the large and the small piston of a hydraulic lift
If the ratio of the diameter of the small piston to that of the large piston is 1:2, how does the forco on the small piston compare with that bon the large piston?
a hydraulic is to be constructed so that a force of 10 Newton can lift a load of 6250 Newton. if the small piston has a radious of 4 cm, what must be the radious of the large piston?
radius
can please somebody help me solve these fallowing problems?
the area of the small and large pistons of a hydraulic lift are 10cm and 500cm, respectively. What load can be lifted on the large piston if a force of 40 Newton is applied in the small piston?
the diameter of the large and the small piston of a hydraulic lift are 6cm and 75cm, respectively. what force must be applied on the piston if a load of 4000 Newton must be overcome by the large piston?
  • · Replies 32 ·
  • · Replies 29 ·
