Angle of inclination (using Newton's Laws)
The problem involves analyzing the motion of a puck on a frictionless air hockey table to determine the angle of inclination of the table based on the puck's drift and velocity. The context is rooted in Newton's laws and kinematics.
  • Participants discuss visualizing the problem and resolving the motion into components along the table and slope. There are attempts to apply kinematic equations and question the setup of the problem, particularly regarding the calculation of the angle of inclination.
Participants are actively engaging with the problem, sharing methods and questioning the correctness of their calculations. Some guidance has been provided regarding the mathematical expressions used, and there is an ongoing exploration of the relationship between the variables involved.
There is mention of potential discrepancies between calculated results and expected answers, as well as confusion regarding the application of kinematic equations in this context.
AshNotKetchum
A physics student playing with an air hockey table (a frictionless surface) finds that if she gives the puck a velocity of 3.44 m/s along the length (2.73 m) of the table at one end, by the time it has reached the other end the puck has drifted 2.08 cm to the right but still has a velocity component along the length of 3.44 m/s. She correctly concludes that the table is not level and correctly calculates its inclination from the above information. What is the angle of inclination?
Relevant equations
Summing forces in x and y directions, according to the question.
The attempt at a solution
I could not visualize a way to solve this question using Newton's laws. The only path to a solution I could visualize was to assume that 2.08 cm was the hypotenuse of a triangle in which the height was the distance the puck had 'fallen', and then solve for theta. However, finding out the distance the puck had fallen has proved to be insurmountable and I may very well be trying to solve this question incorrectly.
You can resolve the motion as one along the length of the table with constant velocity and the other along the slope with acceleration g sin(φ). The components of the displacements are given.
ehild
Thank you for your reply, ehild and I apologize for not replying much sooner with a result.
That gif was quite helpful in visualizing the situation and I thought I understood the problem.
Here is what I did:
Find time taken to for the travel by Speed/distance.
Use the kinematics equation S=ut+(1/2)at^2, where a=gsinθ, u(initial velocity in the direction of the slope)=0, S=distance drifted to the right (converted to m).
I solve for θ using θ=arcsin(2S/g*t^2) but that answer seems to be incorrect. Could you point towards what I'm doing wrong?
Thanks again.
Thanks again.
t^2 has to be in the denominator in the expression for sin θ.
ehild
That is indeed what I meant, sorry for my shoddy mathematical expression.
sinθ=(2S)/(g*t^2)
In this case, θ is 0.15° while the answer to the question is 0.39°.
So, I may have misunderstood you...
When I put the expression as as sinθ=(2S*t^2)/g I got the correct answer, which is a horrible way to go about things. Since our kinematics equation is S=0.5gsinθt^2, I don't understand how t^2 came to be in the numerator to get the correct answer.
Your result is correct. The book might be wrong. ehild
I suppose stranger things have happened.
Thank you very much ehild.
