Angular acceleration in revs/s^2
Angular acceleration can be calculated using the formula α = dw/dt, where dw is the change in angular velocity over time. The discussion highlights a change of 400 rev/min, which needs to be converted to rev/s for accurate calculations. Participants clarify that angular acceleration can be expressed in either rev/min or rad/s, but consistency in units is crucial. The correct conversion from rev/min to rev/s is necessary to avoid errors in calculating angular acceleration. Ultimately, ensuring proper unit conversion leads to accurate results in angular acceleration measurements.
vorcil
http://img15.imageshack.us/img15/858/masteringf.jpg
my attempt,
\alpha= dw/dt
550-150 = 400 rev/min change
400/3.5 = 114 revs
that wasn't right so i tried
114*60, which gives -6857 revs^-2
can someone help please? I'm not sure if I've got this whole revolution thing correct in my head lol
Convert rev/min to rev/s
why does angular acceleration come out right whether you use Angular velocity or revolutions?
\alpha = w/t
\alpha = revolutions/t
You can express angular velocity either in rev/min or rad/s.
In the problem α should be rev/s^2. So you have to convert rev/min to rev/s.
14K
14K
