Angular acceleration of a rod pivoted at an end, at angle below the horizontal
The discussion focuses on calculating the angular acceleration of a rod pivoted at one end and released from a specific angle below the horizontal. The relevant equations include the moment of inertia at the pivot end, Iend = (1/3)ML², and the torque equation t = rF*sin(A), where F is the gravitational force. The derived formula for angular acceleration is α = (3g*sin(A))/(4r), confirming that the mass cancels out in the calculation. The participants clarify the use of the moment of inertia and the assumptions regarding mass distribution.
  • Understanding of angular motion and acceleration
  • Familiarity with torque calculations
  • Knowledge of moment of inertia concepts
  • Basic principles of rotational dynamics
  • Study the derivation of torque in rotational systems
  • Learn more about the parallel axis theorem in physics
  • Explore the implications of mass distribution on moment of inertia
  • Investigate the use of LaTeX for formatting equations in physics
Students studying physics, particularly those focusing on rotational dynamics, as well as educators seeking to clarify concepts related to angular acceleration and torque calculations.
therayne
The rod is at rest and is released, what is the angular acceleration immediately after release? The pivot is frictionless, gravity is 9.8 m/s^2.
Icm = (1/12)ML^2 => Inertia at center of mass, this was given in the problem, i don't think it's necessary though
Iend = (1/3)ML^2 => at pivot end, this was also given in the problem and i confirmed it with the parallel axis theorem
t = rF*sin(A) =>torque, r is the radius(half the total length L), and F is the force of gravity(m*g)
[tex]\alpha[/tex] = t/I =>ang accel
t = rMg*sin(A)
[tex]\alpha[/tex] = (rMg*sin(A)) / ((1/3)ML^2))
since r is half the length of the total length L, i can say L = 2r
[tex]\alpha[/tex] = (rMg*sin(A)) / ((1/3)M(2r)^2))
[tex]\alpha[/tex] = (3rg*sin(A))/ (4r^2) => 'M's cancel out, (1/3) on bottom becomes 3 on top
[tex]\alpha[/tex] = (3g*sin(A))/ (4r) =>simplify 'r'sIs that the right process? I keep getting the wrong answer.
The angular acceleration should be positive right? I know for translational motion, when an object is speeding up it's acceleration is positive, when an object is slowing down it has negative acceleration, and when the rate of change of the speed is constant, the acceleration is 0. So it should be the same for angular acceleration right?
Btw: Is there a way to put LaTeX inside LaTeX code? I was trying to put the greek lower case letter "tau" inside fraction operation for alpha = tau / I but I kept getting an error.
Hi, looks good but I don't understand why you use I=(1/3)MR2. Shouldn't you use the moment of inertia at the center of mass? Can we assume the rod to have uniform distribution of mass?
It's rotating about the pivot though, that's why I used I=(1/3)MR^2.
