What is the Angular Acceleration of a Rod?
The discussion focuses on calculating the angular acceleration of a rod using the formula Aa = Torque/Itot. The total moment of inertia (Itot) is calculated as 235.69784, while the center of mass (Cm) is determined to be 4.915. The initial attempt at calculating angular acceleration yielded an incorrect result of 0.42767 rad/s². The correct approach involves using the distance from the axis to the center of mass for torque calculations, leading to a revised angular acceleration of 0.7 rad/s².
  • Understanding of angular dynamics and torque calculations
  • Familiarity with moment of inertia concepts
  • Knowledge of gravitational force effects on rigid bodies
  • Proficiency in trigonometric functions, specifically cosine
  • Review the derivation of torque in rotational dynamics
  • Study the calculation of moment of inertia for composite bodies
  • Learn about the effects of center of mass on angular motion
  • Explore advanced applications of angular acceleration in engineering problems
Students studying physics, particularly those focusing on rotational dynamics, as well as educators and tutors seeking to clarify concepts related to angular acceleration and torque calculations.
euphtone06
http://img505.imageshack.us/img505/6741/rodprobbw3.gif"
Itot= 1/3MrL^2 + 2/5 MsR^2 + Ms(L + R)^2 = 235.69784
Cm= (Mr(L/2) + Ms(L+r))/(Mr+Ms) = 4.915
angular accel = Torque/Itot
Torque= 1/2Lmgcos(theta)
I solved for Itot and Center of mass and got the correct answers but, I am having a difficult time getting the angular acceleration correct.
Aa= .5Lmgcos(theta)/(Itot)
= .5*6*4*9.8cos31/235.697
= .42767 rad/s^2 which was incorrect
Please help don't know what went wrong!
The 'L' in your angular acceleration formula should be the distance from the axis to the point where the force causing the torque is exerted. In this case the gravitational force can be treated as being exerted at the center of mass, not at the end of the rod.
Do you have to account for the total mass of the system?
.5*4.915*(4+4?)*9.8*cos31/235.697= .7 rad/s^2
4+4? Don't you mean 4+1? Yes, total mass of system. And it looks like the 1/2 in your torque equation is coming from the assumption that the center of mass is the center of mass of the rod. Get rid of it and just put L to be distance from axis to center of mass.
  • · Replies 33 ·
16K
  • · Replies 17 ·
  • · Replies 62 ·
13K
