Angular Momentum of each particle about the origin
8 replies · 3K views
joemama69
Determine the Angular Momentum of each particle about the origin
Point A Located @ (-8,12), 6kg,4m/s, headed 60degrees below the horizon to the right
Point B (2,1.5),4kg, 6m/s, headed 30 degrees above the horizon to the right
Point C (6,-2), 2kg, 2.6m/s, headed on a 5,12,13 angled to the left and down
L=r x p
p=mv
A. -8i+12j X 24(-i-8.66j)=
B. 2i+1.5j X 24(i+.5j)=
c. 6i-2j X 5.2(-12i-5j)=
If this is right i don't know how to calculate it
L=r x p
p=mv
Not quite right. To the right is +i isn't it?
should be
A. (-8i + 12j) X 24*(.5i - .866j)=
should be
B. (2i + 1.5j) X 24*(.866i + .5j)=
should be
c. (6i - 2j) X 5.2*(-12i - 5j -13k) =
To take the cross product ...
http://en.wikipedia.org/wiki/Cross_product#Computing_the_cross_product
(-8i + 12j) X 24*(.5i - 8.66j)
It should be (-8i + 12j) X 24*(.5i - .866j)
Indeed it should. Thanks for the catch.
ok i see my mistakes.
just to clarify @ point C
13 is not the k value, it is the third side of the triangle/hipotinuse
Ok so here what i got
A. (-8i+12j)X(12i-20.784j)=22.72k
B. (2i+1.5j)X(2.784i+12j)=-7.176k
C. (6i-2j)X(62.4i-26j)=280k
A. (-8 i + 12 j) X (12 i - 20.784 j)= 22.272 k
Looking at the original direction again I think it should be -26 i -62.4 j. This yields a different result.
Nope the triangle is not oriented like that
the bottom is 12 or -12i, the side is on the right and up -5j.
joemama69 said:
Nope the triangle is not oriented like thatthe bottom is 12 or -12i, the side is on the right and up -5j.
OK. I can't see the picture, so going with that ... so using -62.4 i -26 j
shouldn't it be -156 - 124.8 = -280.8 k
