Angular Momentum squared operator (L^2) eigenvalues?
terp.asessed
Find the eigenvalues of the angular-momentum-squared operator (L2) for hydrogen 2s and 2px orbitals...
Ψ2s = A (2-r/a0)e-r/(2a0)
Ψ2px = B (r/a0)e-r/(2a0)
If I am not wrong, is the use of L2 in eigenfunction L2Ψ = ħ2 l(l+1) Ψ?
...so I wonder if eigenvalues are l(l+1) from this part, ħ2 l(l+1) Ψ, as in:
for Ψ2s, because for s orbital, l = 0--> l(l+1) = 0(0+1) = 0
for Ψ2px, because for p orbital, l = 1--> l(l+1) = 1(1+1) = 2 ?
That's only the radial part. You are missing the angular part, which is essential ;)
How is an eigenvalue defined?
OMG, I was like, why does the equation look funny----the correct one for Ψ2px would be B (r/a0)e-r/(2a0)sinθcosφ, right?
Also, as how an eigenvalue is defined...well, from one previous eigenfunction example I solved, the one involving Hamiltonian operator, HΨ = EΨ, E is the eigenvalue?
So, is the eigenvalue for Ψ2px2?
Right.
Yes. For an operator ##\hat{A}##, ##\hat{A} \psi = a \psi## where ##a## is a scalar means that ##\psi## is an eigenfunction of ##\hat{A}## and ##a## its corresponding eigenvalue.
Yes.
I don't know what the level of the question is, so I don't know how simple the answer can be. If this is an advanced problem, you probably are expected to actually derive the eigenvalue.
Likes terp.asessed
Thank you! I am quite surprised myself at how simple the answer turns out to be...but still thank you.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
