Angular Momentum vs Linear Momentum
The discussion revolves around a physics problem involving a rod and a particle, focusing on the concepts of angular and linear momentum. The participant is trying to determine the correct approach to calculate the angular speed of the rod after a collision, questioning whether to use linear or angular momentum equations. They present two equations, noting that the second equation seems to yield the correct answer, but they are confused about why linear momentum is appropriate in this context. The conversation emphasizes the importance of ensuring dimensional consistency in the equations used. Ultimately, clarity on the application of momentum types is crucial for solving the problem accurately.
Maged Saeed
The following figure shows an overhead view of a thin rod of mass M=2.0 kg and length L = 2.0 m which can rotate horizontally about a vertical axis through the end A. A particle of mass m = 2.0 kg traveling horizontally with a velocity $$v_i=10 j \space m/s$$ strikes the rod (which was initially at rest) at point B. the particle rebounds with a velocity $$v_f=-6 j\space m/s$$. Find the angular speed of the rod just after the collision.
$$(I\omega)_i=(i\omega)_f$$
I have tried to solve this question using the previous equation , but I'm stuck with the momentum of the ball . Should it be linear or angular?
I mean ;
which of the following equation should i use :
1)
$$(mvl)_{ball}=(I\omega)_{rod} +mvl$$
$$(2 \times 2 \times 10j)=(\frac{2 \times 2^2}{12}+2 \times 1^2)+2\times 2 \times -6j$$
The moment of inertia of the rod is:
$$\frac{ml^2}{12}+mh^2$$
where h is the distance from the center of mass to the axis of rotation.
2)
$$(mv)_{ball}=(I\omega)_{rod}+mv$$
$$ (2 \times 2)=(\frac{2 \times 2^2}{12}+2 \times 1^2)+(2 \times -6j)$$
The equation 2 seems to lead to the correct answer , but , why i should take the linear momentum instead of angular momentum!Help please!
Which equation has the same dimension for all terms ?
Yeah , ..
How it comes that I didn't pay attention to this point ..
Thanks ..
  • · Replies 17 ·
16K
  • · Replies 62 ·
13K
  • · Replies 18 ·
