Angular momentum with rotating disk and point mass
EngAM
I've spent at least 1.5 hours on this problem trying to figure out what i did wrong and I can't find anything. With an exam in two days plus another chapter to go through.
Regardless, here are the problem(6) and answer, as well as my work. Hope you can read it, and the writing on the bottom left in red was just a variation of me using a negative value for m1(B/4) , as oppose to a positive like the right.
/ work[/B]
problem and answer:
https://imgur.com/a/C440LPp
work:
https://imgur.com/a/A0KP8VU
Thank you very much
Also, I'm new here so i don't know how embed images.
Problems:
Photo of a textbook page showing a rod pivoted at its center with two ants at B/4 from the center on either side, and a handwritten-style solution on the facing page with the formula r = sqrt((B/4)^2 + (m1/m2)at^2[B/2 - at^2]).
Left side of board:
Whiteboard photo: a rotating disk with a small mass m1 on a rod and mass m2 at the edge, with a balanced lever diagram; right side shows angular momentum equations and a handwritten derivation with terms m1(r/4)^2, m2 and x^2.
Right side of board:
Handwritten angular momentum derivation on a whiteboard: L_initial equals m1 times (B/4) squared times omega, plus m2 times (B/4) squared times omega, with the second line of L_final expanded in terms of m1, m2, B and omega.
  • Whiteboard photo: a rotating disk with a small mass m1 on a rod and mass m2 at the edge, with a balanced lever diagram; right side shows angular momentum equations and a handwritten derivation with terms m1(r/4)^2, m2 and x^2.
  • Handwritten angular momentum derivation on a whiteboard: L_initial equals m1 times (B/4) squared times omega, plus m2 times (B/4) squared times omega, with the second line of L_final expanded in terms of m1, m2, B and omega.
  • Photo of a textbook page showing a rod pivoted at its center with two ants at B/4 from the center on either side, and a handwritten-style solution on the facing page with the formula r = sqrt((B/4)^2 + (m1/m2)at^2[B/2 - at^2]).
Welcome to the PF.
You use the UPLOAD button in the lower right of the Edit window to upload a PDF or JPEG image. Your work is hard to read at that resolution, so you may want to take several pictures closer to your work to make it more clear. Normally we prefer that the work is typed into the PF, using the math symbols under the Sigma ∑ symbol in the toolbar at the top of the Edit window, or using LaTeX (see the tutorial under INFO, Help/How-To at the top of the page).
Welcome to the PF.
Hopefully you can read it now? Sorry, my camera quality is just poor. But like I said, I feel like I "solved" it right conceptually, i feel like it might be somewhere in my work that's wrong. I know there shouldn't be any torque so angular momentum is conserved, which is why I said total initial momentum (I add the momentums of the separate ants together right) is equal to the total final momentum.
