Angular Oscillation of a rod in a circle
1 reply · 3K views
Tanya Sharma
A uniform rod moves in a vertical circle .Its ends are constrained to move on the track without friction.Find the angular frequency of small oscillation .
Suppose the rod of length L moves in a circle of radius R .
Let the equilibrium position of the rod be AB .X be the mid point .CD is the position of the rod when it displaced by an angle θ .Y is the mid point.
The mechanical energy of the rod in position CD is denoted by E .
The moment of inertia of the rod about its CM (the middle point) is Icm
The moment of inertia of the rod about O is I .
[itex]I_{cm} = ML^2/12[/itex]
[itex]I=I_{cm} + Md^2[/itex]
[itex]I=M(R^2-\frac{L^2}{6})[/itex]
[itex]E= mgd(1-cos\theta)+(1/2)I\dot\theta^2[/itex]
Differentiating E w.r.t time ,we get
[itex]dE/dt = mgdsin\theta\dot\theta+(1/2)I(2\dot\theta\ddot\theta)[/itex]
Since Mechanical energy remains conserved ,
Putting dE/dt=0 ,we get
[itex]\ddot\theta = -\frac{mgdsin\theta}{I}[/itex]
Using small angle approximation , sinθ≈θ
[itex]\ddot\theta = -\frac{mgd\theta}{I}[/itex]
Is my approach correct ?
Looks right to me. (It's clearly the same as making a pendulum out of the rod by attaching a light bar length d rigidly, at right angles, to its centre.)
