Angular Velocity [SOLVED] for Flywheel Generator Problem
The discussion addresses the calculation of angular velocity for a flywheel generator with a given angular acceleration function a(t) = 6bt - 12ct². The initial attempt to find angular velocity w(t) = w0 + at was deemed incorrect, as it misapplies equations meant for constant angular acceleration. The correct approach requires integrating the variable angular acceleration over time. The distinction between constant and variable angular acceleration is emphasized, highlighting the need for proper integration techniques. Understanding these principles is crucial for accurately solving problems involving angular motion.
kasse
[SOLVED] Angular velocity
The angular acceleration of a flywheel of a generator is given by
a(t) = 6bt - 12ct2
What is the angular velocity at t when the initial velocity is w0?
w = w0 + at = w0 + 6bt2 - 12ct3
This is wrong according to my book. Can't I use the same equations for angular motion as for linear motion?
The equation you have written is for solving angular velocity when the angular acceleration is constant.
