Angular Width of Electromagnetic Waves emerging from two buildings
The discussion revolves around calculating the angular width of electromagnetic waves emerging from a gap between two buildings, using a cell phone signal at 800 MHz. The wavelength is determined to be 0.381 m, and the gap between the buildings is 15 m. The main approach suggested involves using the single-slit diffraction formula, specifically theta = sin^-1(wavelength/a), but there is confusion regarding whether to use the full gap or half of it in the calculations. Participants clarify that the angle calculated does not represent the angular width of the central maximum, prompting further exploration of the correct approach. The problem remains unresolved, with contributors seeking clarity on how to accurately determine the angular width.
randyjstark
Hello everyone,
I have one more problem left of my homework and I seemed to be stumped. I don't even know where to begin with this problem, which comes from the section of my book labeled Single-Slit Diffraction. Anyways, here is how the problem reads:
Problem 22.18
You need to use your cell phone, which broadcasts an 800 MHz signal, but you're behind two massive, radio-wave-absorbing buildings that have only a 15 m space between them.
What is the angular width, in degrees, of the electromagnetic wave after it emerges from between the buildings?
I calculated the wavelength at 800mhz = .381m
a= 15m (distance of the slit OR distance between two buildings.
Due to the slit being so large, I am not sure how to approach the problem. I assume that we cannot use a small-angle approximation due to how large the slit and wavelengths are.
I think the equation to use would be the following
delta r= a/2 *sin(theta) = wavelength/2
However, I am not sure how to rearrange to get theta.
I tried rearrangeing to get aSin(theta) = wavelength => theta = sin-1(wavelength/a) and got 1.43 degrees. Would this be correct or did I just hammer the problem?
If anyway can give me a hand (or somewhere to start) I would really appreciate it.
Thanks,
Randy
I've never heard of the "angular width...of the electromagnetic wave" before. I'm assuming that they meay the angular width of the central maximum.
Yes, a would be the slit width.
Approach it like any other single-slit diffraction problem.
I agree that you need to find \theta=\sin^{-1}(\lambda/a). But you need to think about what angle that represents. That is not the angular width of the central maximum. So let me ask you, what angular width is it?
I do not know what angular width that represents. my book does not go into anymore details about this type of problem. Instead of just using a = 15m would I use a/2 = 7.5m? I do not know what else to do for this problem. I am kind of stumped.
