Another Newton law theoroy question
The discussion revolves around a physics problem related to Newton's laws, specifically focusing on the forces acting on an armchair being pushed across a carpet at constant speeds. The original poster presents a scenario where a force of 100N is applied to maintain a constant speed, and questions how this force changes when the speed is doubled.
  • Participants explore the implications of Newton's second law and the concept of net force when the velocity is constant. Questions are raised about the nature of the resistive force counteracting the applied force and how it might change with increased velocity.
There is an ongoing exploration of the problem, with participants questioning the sufficiency of the provided information and discussing the relationship between applied force and resistive forces, particularly in the context of friction.
Participants note that the problem is derived from a practice section of a textbook, indicating a potential limitation in the details provided for analysis.
narutodemonki
pushing an armchair across a carpeted or at constant speed v you apply a force of 100N
if you push same chair at constant speed 2v(twice as fast) you mush push with a force?
a)100N
B)141N
Newtons second law? if the net force acting on object is zero or if no force is acting on object..objects at rest will stay at rest and objects in uniform motion will stay in uniform motion in a constant velocity straight lien unless acted on by a non negative resultant force.
...since the speed is constant that means no force is being applied? but the initial force was 100N? and was 100N for a while until the 2v speed was reached?
If the velocity is constant, that means that no net force is being applied. Which means that something is counteracting the 100N being applied, what force is that?
If you double the velocity, how will that resistive force respond? (look at how the equation for that particular resistive force varies with velocity)
It sounds like a friction problem, however I'm not sure you have given enough of the details to solve.
Well the question is straight from the practice section of the text. That is all the info they have given.
Yes, for this type of problem (simplicity-wise), its enough information.
  • · Replies 62 ·
