Another one about Yield Stress....
2 replies · 2K views
Jens Wensing
Hi Forum,
I´m happy I found this forum...
I hope someone can answer my (simple) question:
According to this thread https://www.physicsforums.com/threads/calculating-0-2-proof-stress-of-aluminium.206648/ on page 2 the stress/strain diagram is not the same as force/elongation.
Due to the constant area surface and the constant start length, the graphs look the same.
Now the question:
Am I wrong when I use the force/elongation graph for further studies? (e.g. Yiel point 0.2% determination). Or did I miss another influence?
Background:
We build bending machines and need to find out the Yield point of mainly Aluminium material. The parameters we have can gather are:
- Force
- position (length)
- Time (Speed)
- We can input length and areal surface in a programmed mask
Thank´s a lot and excuse my maybe too simple question...
Jens
Jens Wensing said:
Hi Forum,
that is correct, they are not the same
they both are generally linear, but the slopes of the 2 graphs are quite different, however.
Now the question:
Am I wrong when I use the force/elongation graph for further studies? (e.g. Yield point 0.2% determination). Or did I miss another influence?
in determining the yield stress of the material at 0.2 percent strain, you can use the force - elongation graph, and determine the elongation at 0.2% length, then find the force at that elongation. The force must then be divided by the cross section area to get the yield stress at .2 % strain
Background:
- Force
- position (length)
- Time (Speed)
Jens
I assume you are measuring force and elongation in a tensile testing apparatus? And it is not surface area, it is cross section area you want to use.
PhanthomJay said:
that is correct, they are not the same they both are generally linear, but the slopes of the 2 graphs are quite different, however. in determining the yield stress of the material at 0.2 percent strain, you can use the force - elongation graph, and determine the elongation at 0.2% length, then find the force at that elongation. The force must then be divided by the cross section area to get the yield stress at .2 % strainI assume you are measuring force and elongation in a tensile testing apparatus? And it is not surface area, it is cross section area you want to use.
Thank you very much for your reply.
The test happens in a production machine, where we have the possiblitiy to measure force (calibrated suitable for our needs) and displacement (elongation).
Of course I referred to cross section area, that had been lost in translation ;-)
We have input possibilities of the cross section area of the used profile.
So I can go on with the programming.
Thanks again
