Another paradox from the force transformation laws?
The discussion revolves around the force transformation laws in special relativity (SR) and the paradoxes that arise from them, particularly in the context of two objects interacting while in relative motion. Participants explore the implications of these laws on Newton's third law and conservation of momentum, examining the scenarios from different inertial frames.
  • Jeff presents a scenario involving two objects where the force exerted by one object on another appears to violate Newton's third law when viewed from different inertial frames.
  • Some participants suggest that the resolution of the paradox may involve the relativistic transformation of angles, noting that force components transform differently depending on the frame of reference.
  • There is a discussion about the distinction between the components of velocity in the direction of the force and those perpendicular to it, with some disagreement on the interpretation of these components.
  • Jeff proposes that the paradox may be resolved by considering the change in rest mass of an object when it exerts a force, suggesting that the force transformation laws assume constant rest mass, which may not hold in this scenario.
  • One participant emphasizes that the definitions of momentum used in the two scenarios differ, which may contribute to the perceived paradox.
Participants do not reach a consensus on the resolution of the paradox. Multiple competing views and interpretations remain, particularly regarding the implications of force transformation laws and the nature of momentum in different frames.
Participants express uncertainty about the assumptions underlying the force transformation laws and the implications of changing rest mass during interactions. The discussion highlights the complexity of applying classical concepts like Newton's third law in relativistic contexts.
jeffwu78
Hi all,
I've been recently digging into SR in my attempts to better understand electromagnetics. One thing that has been giving me trouble is the force transformation laws, which seem to give rise to some pretty gnarly paradoxes, one of which I've listed here:
Consider two objects, where object 2 is moving at a velocity v relative to object 1. There is a moment when both objects just touch, at which time object 1 exerts a force F (perhaps via an expertly-timed spring release) perpendicular to the direction of motion of object 2. Assuming Newton's 3rd law holds, then object 2 exerts a force -F on object 1.
Now consider the same scenario from the inertial frame of object 2, so that object 2 is now at rest, and object 1 moves with velocity -v relative to object 2. According to the force transformation laws, the force exerted by object 1 on object 2 is F/sqrt(1 - v^2/c^2), but the force exerted by object 2 on object 1 is F*sqrt(1 - v^2/c^2). The paradox is that Newton's 3rd law does not seem to be preserved by changes in the inertial frame.
Besides the lack of symmetry, the thing that most troubles me about this paradox is how can we have the conservation of momentum hold between inertial frames and yet Newton's 3rd law fail to hold?
Any answers would be greatly appreciated. But please answer only if you know what you're talking about.
Thanks,
Jeff
I haven't taken the time to go through this in detail, but I suspect that the resolution of the paradox has to do with the relativistic transformation of angles. The perpendicular and parallel components of the force transform differently. A force that in one frame of reference is perpendicular to the line of motion will not be perpendicular to the line of motion in another frame.
Another thing to consider is that you really have three motions: the motion of object 1's center of mass, the motion of object 2's center of mass, and the motion of the point of contact.
The v in those equations refer to the components of velocity in the same direction of the force applied, not in a perpendicular direction.
No, it's perp.
The force is y^3 times longitudinal acc and y times transverse acc, whole multiplied by rest mass
jeffwu78 said:
Hi all,
Jeff
Fact is:In both cases, it is what you said in the second case.Difference is:The first case uses momentum is mv, the second uses ymv
Thanks for all the replies. But what do you mean by the first or second case? The two scenarios are describing the same events, but viewed from different inertial frames.
Jeff
After going crazy about this paradox for a couple of days, I think I have a good hunch of how to resolve the paradox. The key is that object 1 must use some of its internal energy (for example, in a compressed spring) in order to exert the force on object 2 for any nonzero period of time, and thus loses some of its "rest mass" in the process, due to mass-energy equivalence.
If one defines force to be the rate of change of momentum, and the conservation of momentum always holds, then Newton's third law also must hold. The issue is with the force transformation laws, which implicitly assume that the rest mass of the object in question is constant. But here the "rest mass" of object 1 changes with time, so the force transformation laws for object 1 no longer hold.
If/when I can give a mathematical proof for the resolution of this paradox, I will post it on this thread.
Jeff
  • · Replies 55 ·
  • · Replies 30 ·
  • · Replies 24 ·
  • · Replies 27 ·
  • · Replies 34 ·
  • · Replies 18 ·
  • · Replies 26 ·
