Answer check-derive a general formula for horizontal displacement
The discussion focuses on deriving a formula for the horizontal distance a projectile travels when launched horizontally from a height, h. Participants explore the relationship between time of flight and height, emphasizing that the time to reach the ground can be calculated using the equation t = √(2h/g). The horizontal displacement is then expressed as x = vi * t, leading to the final formula x = vi * √(2h/g). The conversation highlights the importance of incorporating height into the calculations and confirms that the horizontal launch angle (θ) is zero, simplifying the trigonometric considerations. Overall, the derived formula effectively links the initial velocity and height to the horizontal distance traveled.
negation
Derive a general formula for the horizontal distance covered by a projectile launched horizontally at speed vi from height, h.
vyf = vyi -gt
t = vyf/g
x = vxi .t = vi cosΘ (t = vyf/g) = [vi^2 sinΘcosΘ]/g
The launch is horizontal, so your theta is known. You run into trouble with sin theta, which is 0.
Also, I don't find any dependence on h. Don't you think that if you launch from a high fortress, the projectile covers a bigger distance than if you launch from a small hill ?
Tip: make a drawing!
My solution was to find the time taken for the projectile to reach the ground. Then sub that time, t, into the horizontal displacement formula vi cos Θ .t. Is there a reason why this is not viable?
The idea is excellent. But don't you think that h should appear somewhere in that time ?
You replace vyf by vi sin theta. That is not good. In the first place because vi sin theta is 0. In the second place
because vyf = gt.
Made a drawing yet ?
because vyf = gt.
I have the drawing already. It's really just the second half of the parabola.
because vyf = gt.
It's not an issue, is it? Since Θ = 0°, then, vi sin(0°) = 0.
Two approaches possible, in fact they are the same.
You can get vyf from an energy balance mgh = 1/2 m vyf^2
or you can get vyf by solving for y(t) = 0 the equation y(t) = y0 + vyi * t - 1/2 * g * t^2 an using that t in your expression for x.
It struck me that the equation y(t)= y(0) + vi.t -0.5gt^2 can be reduced to y(t) - y(0) = h = vi.t - 0.5gt^2. From there I can solve for time. I think this approach is a parallel reasoning to the one in my attempted solution and hence I do not think my answer in the OP is wrong. The only difference would be that using h allow me to express the solution in the intended manner the question demands.
h = vyi.t - 0.5gt^2
but since yf < yi , then, yf - yi = -h, and vyi = 0 since vi sin 0° = 0
hence, - h = -0.5gt^2
t = SQRT[2h/g] (time taken for projectile to reach the ground)
given time, t = SQRT [ 2h/g], the horizontal displace in this period of time
= vxi.t = vi cos(0°) [SQRT[2h/g]] = vi[SQRT[2h/g]]
Excellent.
9K
9K
13K
  • · Replies 17 ·
17K
