- Messages
- 2,188
- Reaction score
- 2,694
As part of our UG curricula in Physics major, we have a practical in which we have to draw the calibration curve of an NTC ##10~\mathrm{\Omega}## thermistor, and then construct a circuit to maintain the temperature of a water bath.
The calibration curve of our thermistor. The Prof. said that this is more or less fine.
The circuit, shown below, uses two LM741 Op-Amps. The first Op-Amp is a non-inverting amplifier, which amplifies the voltage ##V_t##, the potential difference across the thermistor. The second Op-Amp acts as a comparator.
We have used ##R_1 = 2.2~\mathrm{k\Omega}##, ##R_2 = 22~\mathrm{k\Omega},## ##R_L = 5~\mathrm{k\Omega},## ##R_B = 15~\mathrm{k\Omega},## and a ##1~\mathrm{k\Omega}## potentiometer.
Suppose we want to create a temperature controller at 63°C. First, using the calibration curve, we find the potential difference (##V_t##) across the thermistor at this chosen temperature. The voltage at the output of Op-Amp 1 will be ##A_v V_t##, where $$A_v = 1 + \dfrac{R_2}{R_1} = 11$$ is the gain of the non-inverting amplifier. This voltage will be applied at the non-inverting input (##V_{2+}##) of Op-Amp 2. Next, using the potentiometer, we set the voltage at the inverting input of Op-Amp 2, ##V_{2-}##, to very close to, but slightly less than ##V_{2+}##. When switched on, the comparator is supposed to output either ##+V_\mathrm{sat}## or ##−V_\mathrm{sat}## based on the differences in the input. This voltage will be applied to the base of the transistor CL-100, which will turn the relay on accordingly. The relay controls the electric heater which heats the water bath.
Simple enough? Yes, theoretically. We have been facing a really hard time for the last two days (nearly seven hours total) in trying to make this circuit work.
At first, we were not getting the required gain from the first Op-Amp. The Op-Amp output was just getting saturated. The Prof. said that it might be due to loose connections. We re-did the circuit today, and the gain was coming okay. But then, the second Op-Amp never gave a proper output. We checked voltages everywhere; things were getting erratic. The thermistor was voltage ##V_t## was not coming to the first Op-Amp, if it did come, the output saturated. If we fixed that, the set voltage at ##V_{2-}## floated away. The Prof. sat with us and checked everything; the circuit was perfect. But the voltages were erratic. He couldn't help us, and blamed us and on our patience.
We use a lot of banana connectors — connections to the thermistor, to the power supply and to the relay. The Prof. said that these were having loose connections as the wires were not soldered inside them. But the lab assistants won't solder. I will try to have a word with the HoD to see if I can bring the male banana connectors home for soldering.
Other than that, is there anything which we can check to troubleshoot? We will get just one more day for this.
