Any truth to discharging our bodies?
  • Context: Undergrad
  • Thread starter Thread starter pinchharmonic
    bodies
The discussion centers on the efficacy of "earthing" or "grounding" pads, which claim to discharge excess charge from the human body. Participants assert that while the human body can accumulate static charge, the medical claims regarding inflammation are dubious. Grounding techniques, such as using ground straps in the semiconductor industry, are acknowledged as effective for preventing static discharge damage. However, skepticism remains regarding the health benefits promoted by grounding products.
  • Understanding of electrostatics and charge flow
  • Familiarity with grounding techniques in electronics
  • Knowledge of static electricity and its effects
  • Basic principles of capacitance and voltage potential
  • Research the principles of electrostatics and charge accumulation
  • Learn about grounding techniques used in semiconductor manufacturing
  • Investigate the scientific studies on the health effects of grounding
  • Explore the role of humidity and environmental factors in static charge dissipation
This discussion is beneficial for electrical engineers, semiconductor professionals, and individuals interested in the scientific basis of grounding techniques and their purported health benefits.
pinchharmonic
there's at least one company that sells these "earthing" or "grounding" pads that are connected to the ground port in the wall socket. Allegedly they help "discharge" human bodies, which generally have too much charge, causing inflammation in the body.
whether or not charge in the body causes inflammation is probably not appropriate here, but what about a human body carrying charge, and discharging it by being connected to the earth?
Earth is a huge capacitance, which means it could store more charge given the potentials are the same comparing to human body, since V=Q/C. Therefore charge would continuously flow into eath until same potential is reached so that charge is in equilibrium.
Save your money, Pinch. They're full of ****.
It is true. I used to work in the semiconductor industry and all of the manufacturing personal wore ground straps on the shoes and sometimes ground wires to the wrist as well. The body can pick up a static charge and will damage the semiconductor if discharged through it.
I'm (very) skeptical of the medical claims though. There is always stuff like this being sold.
Note that the workbench pads also need to be grounded. The main issue is for the person and the pad to be connected so they are at the same potential, so there's no net voltage between the person and the pad that the senstive component is being worked on, otherwise current could flow between the person and the pad via the sensitive component.
Unless there's some near infinite resistance between you and the earth, you'll slowly discharge any static that you've built up. You can't shuffle your feet across a rug, then wait 30 minutes and then try to get a spark by reaching for a door knob.
I don't recall any claims that the guys that work on high voltage AC lines (wearing a Faraday cage like suit) having any health issues. They get onto the lines via a helicopter away from any Earth ground source, using a rod then cable to equalize the potential (note it's an AC line, so the potential is cycling) between the line, person, and helicopter. Example youtube video:
I imagine the resistance of a rubber-soled running shoe is fairly high.
The ground straps I mentioned had 10 MegOhm resistance, for safety reasons.
Electrostatically charged objects (such as humans) loose their charge to the air (especially if its wet), although it happens slower than if you are holding a metal ground wire. You don't have to be physically grounded to slowly loose electrostatic charge. The early pioneers in electrostatics, such as Coulomb, noticed this. They learned to run their experiments in the cold dry winter air or in vacuum to avoid charge leakage to air degrading their results.
10K
  • · Replies 19 ·
  • · Replies 32 ·
  • · Replies 24 ·
