Anybody help with these questions?
  • Thread starter Thread starter scw1
5 replies · 2K views
scw1
A spherical pressure vessel has been designed such that the tensile stresses in its walls should not exceed 150MPa. The ratio of the vessels radius to wall thickness is 100. Applying a thin-walled plane stress assumption, what is the maximum uniform internal pressure that the vessel is intended to contain?
Thin walled pressure cylinder assumption P= sigma(s) x radius/2xt(s)
i tried the answer 0.15MPa but not sure if its right can anyone help me??
rock.freak667 said:
Your equation should read σ= (Pr)/t or P = σt/r
Hi how do you denote the radius to wall thickness, is it 100 to 1 or 10 to 0.1?
Many thanks
Stevo
Many thanks
Stevo
since r is the radius and t is the wall thickness
radius to wall ratio = 100 OR r/t = 100.
nvn said:
Good advice by rock.freak667, except the equation should be sigma = p*r/(2*t).
Yes it should, I was thinking about a thin-walled cylinder.
